Mobile Helicoil & Broken Stud Removal / Specialist Around Canley Area?
Hey guys,
Typical RB shenanigans, cylinders 1 & 6 have broken studs.. and looks like in the past the previous owner tried to remove them himself/herself and left a mess on cylinder one with like chisel marks etc.. and a threaded hole.
So pretty much the car is in my backyard without a manifold on and 3x broken studs and 1x stripped thread on cylinders 1 and 6.
I will require the service of someone here or professional to:
- remove 3x broken studs
- helicoil 1x stripped thread
To help with the service, I have at home an air compressor, a corded drill, cordless drill, 90 degree drill adaptor, enough tools, etc..
I prefer to not to attempt this myself on the motor as I don't want to make it worse, if it was out of the car I would give it a crack.
I've been quoted $300 to get it removed, but that's pretty steep.
Hopefully under $200 and I'll pay with cash and throw in a few free beers :)
Cheers,
Johnny
hectic, after calling about 4 places/people
Greg at Action Thread Repairs, happy to do it for $200 ish mobile service too.. scheduled in for Monday.. BAM!
Good score for $200 Johnny for the amount of work involved!
I'm assuming (I hardly ever do this, as assumations are the mother of all f#%kups) that your talking about exhaust studs.
Now is the time to replace the lot with new 316 stainless studs, nuts & flat washers.
I'd also recommend using nickel based anti-seize to facilitate easier removal further down the track, however, DO NOT over torque the nuts, as when anti-seize is used will result in over torquing, unless it has been factored into the torque specifications.
I generally reduce torque by 25%, if not factored in by manufacturers specs due to the lubricating properties of it.
The most common brand sold is Unasco Nickel anti-seize compound.
Let's see how it goes Monday haha.. Greg did say it might be a little more.
Good tip, I'll buy some anti seize this weekend. Supercheap should have it right?
#nissanlife lol
so everything done, however the very last thread, there are 2x easy outs stuck in it & weld marks all around it..
Looks like the previous owner had a go and mad a mess out of it.. Greg said it will be a PITA to drill it out and fix it up.. so I opted for just fixing the other studs and leaving that 1x stud untouched..
I hope it doesn't leak :(
hope so :)
turbo, manifold, gaskets, studs, lines are all in.. even chopped my RS*R downpipe and welded 2x bends to fit up to the turbo's v band flange.
just need a screamer pipe and my exhaust wrap to come and let's see how she goes :D
but but but... I'm running an external gate :)
trust the car is super quiet, I'm planning to mod my exhaust to make it even MORE quiet. I'm running 1x mid muffler, 1x resonator, 1x rear cannon muffler. Will be changing the mid muffler to a hooker aero chamber item soon.
So for normal driving conditions, it would be probably as loud as a stock car, until I crack zeee gate hehe
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
