Compression Test Results
GTROID
 Share
Few weeks after installing new turbo i had lots of white smoke when lifting off after heavy acceleration, had parked car up for a few weeks before looking at the problem, smoke was more evident this time around, really bad after a good hit on boost, when pulling up at home it was puffing smoke out exhaust on idle, so i've done a compression test.
Did test cold as im not that keen on driving the car to warm it up, for wet test i added 3ml of oil. All with open throttle.
cyl 1 cyl2 cyl3 cyl4 cyl5 cyl6
dry 136 dry 125 dry 125 dry 125 dry 130 dry 40
wet 144 wet 134 wet 137 wet 133 wet 143 wet 48
Does this indicate valve seal? Is there any further tests i should do?
If it is the valve seal is it fine to fix the issue and refit the head or should i pull the motor out and have it inspected?
Appreciate some feedback, thanks guys :)
I would be looking more to valve seat, valve itself and possibly the valve guide. A leaky valve stem seal would give you oil in the combustion chamber which you said you have and you should technically still have compression in the cylinder.
If the valve head had dropped off you would have heard it rattling around inside your cylinder or even worse in the back of your turbocharger and if the valve was jammed wide open or the valve head missing the comp would either be zero regardless of a wet or dry test.
I had an engine at work with 15psi in a comp test and it ended up been a torched valve face but this was on a large industrial gas engine running around 700degree exhaust temps so torched valves and recessed seats are pretty common hence why we change heads out every 20,000 hours whether they need it or not.
Perhaps pull the rocker cover and see if any of the valve springs are excessively loose or if any of the valve heights are different as they should be relatively close to one another. That will either give you and indication of a recessed valve seat causing it not to seal 100% and if a valve is missing the head the valve spring will be sitting higher than the rest of them and the spring will be loose and very easy to turn.
At the end of the day the head will be coming off regardless but if all looks good there you could be looking at a piston
You will need to remove cams to check spring heights correctly. Recessed/leaking valves will give low comp readings wet/dry hot or cold. A torched valve will give the closest to zero reading, providing the rings/lands are in good nick.
Either way the head has to come off & checked before you decide to pull the whole lot out as #6 is f%#ked.
Question 1: Why was the turbo replaced?
Question 2: How many K's has your engine done?
You state its white smoke coming from the exhaust. Does it smell sweetish like glycol/coolant?
Have you had any coolant loss?
If you run over 12-14psi, have you done a head stud conversion?
Had a boost leak and when trying to find that i had checked the turbo which had massive amount of shaft play, so it was replaced, running 14 psi and have not done head stud conversion.
Motor has bout 150 on it.
It has a bit of a smell but isn't a coolant smell i don't think? will check that, coolant is clean and oil is normal looking, no milkyness.
No coolant loss, lots of oil in all the cooler piping etc which i expected to see.
According to receipts in the glove box from previous owner 'Sensor drive gear in camshaft worn causing erratic timing control. Removed cam sensor, clean area where gear and spline connect. Under customer instruction fixed sensor drive to camshaft with devcon.'
I don't fully understand as i havn't seen the setup for that but that seems dodgey as f... to me? Wouldn't you just replace the CAS?
The actual drive in the cam wears out so replacing the cas won't fix it. Only way to fully fix it is new cam .
Did you clean out all the pipework and intercooler of the oil from dud turbo?
Edited by superben
Ok thanks could that be likely to cause valve issues long term?
Yeh cleaned all that out, will probably pull motor out, after talking to a few people it sounds like its at that age for a rebuild anyway, thanks all. :D
Devcon is bog for metal. We use it sometimes on lower liner fits when they pit & leak on engines in the field. It's not to bad a temoprary fix when the customer doesn't want to blow a million bucks (literaly-I'm not joking)! A set of cams in an RB on the other hand, you'd get away with poncams, sprockets & a tune for around the $2k mark.
 Share
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
