Bov Making Car Hunt?
sleptema
 Share
Hi all.
Tried to search for the issue, but I didn't have much luck finding anything relating directly to my issue.
Car has a stock blow off valve, plumbed back. Decided to make a plate to block it off, you know for flutter/dose/compressor surge whatever you want to call it.
Car runs great, starts fine, idles fine, holds boost, flutters...
But if I am idling and rev it slightly, then take my foot off the throttle, it hunts for a while then goes back to idling fine. Sometimes it drops to 100-200 rpm, sometimes just to 600, stalled a couple times. It doesn't ALWAYS do it. It is mainly a concern when I am in traffic and need to move forward slightly. Black smoke also comes out the exhaust when hunting. Rich?
Is it because it was tuned with the plumb back blow off and it is expecting that air for idle and isn't receiving it? I have blocked the vacuum line going to the bov and the plumb back pipe. I haven't tried plumbing the bov back in and taking out the blanking plate. Will do that soon and report back.
R34 gt-t rb25det neo
Garret low mount on 18psi
avc-r boost controller
power fc
supporting mods
It's because of the reverberation caused affecting the afm.
The ecu sees it as more airflow and adds fuel.
Flutters are not cool enough to put up with your car running shit.
Edited by superben
I use pfc and have no probs, would like a return pipe but its a long way back to the hot side from my bov, one day I 'll have a hard line, but it works fine the way it is, no map ecu needed
Or plumb it back and live a happy life. :)
this...seems pretty simple to me mate...you changed something and it made it worse...
Now 'Im not the sharpest tool in the shed but i'd thunk the smart thing to do would be change it back ;)
Mine fluttered with an AFM, had the bov plumbed straight into the intake pipe at 90 degrees, not facing the turbo as recommended. Never had any issues
Mine didnt flutter like crazy because I softened the bov but when it did it was fine
If it flutters, the BOV is supposed to be blocked, doesn't matter if it is plumbed or not..
Yeahhhhh.... It will flutter blocked or with the BOV spring tightish. It isnt 'supposed' to be bocked
How do you tighten the BOV spring?
I didn't think the flutter would have have as much as effect as it did on my car, it is a low mount garret with a LARGE FMIC, and no forward facing plenum. So much frikken pipe work, wouldn't have thought it would have made it that far back..
 Share
    • Remember our cars are 30+ years old so expect the rubber bits to leak. I'd go around your engine bay with a can of "start ya bastard" or similar and look for leaks. FYI I got my car 10+ years ago with the standard boost restrictor in place, I removed it when I got it and the car never had any issues since (besices a leaking manifold gasket). tl;dr- Look for leaks before proceeding.
    • That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use). They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
    • I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it. 1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets. 2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine. 3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started. 4. The oil pick up can be removed with the gap available.  5. The oil pan can be removed now. 6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides. 7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off. 8. With one person supporting the oil pan the other can fit the oil pickup 9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal. 10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
    • I find building an exhaust a really satisfying job! Looks nice!   Did you consider using an oval pipe to get the same cross sectional area but keep it above the chassis rail?
    • @Dose Pipe Sutututu Sounds good.  Just double checking with the pull up resistor indicated in haltech's info sheet for their SSR - https://www.haltech.com/product/ht-030202-solid-state-relay-100-amp/  I'm guessing that would only be if the ECU did not have an internal pull up resistor? Their instructions are pretty strongly worded lol "1K pull-up resistor MUST be fitted."
