Bov Making Car Hunt?
sleptema
 Share
Hi all.
Tried to search for the issue, but I didn't have much luck finding anything relating directly to my issue.
Car has a stock blow off valve, plumbed back. Decided to make a plate to block it off, you know for flutter/dose/compressor surge whatever you want to call it.
Car runs great, starts fine, idles fine, holds boost, flutters...
But if I am idling and rev it slightly, then take my foot off the throttle, it hunts for a while then goes back to idling fine. Sometimes it drops to 100-200 rpm, sometimes just to 600, stalled a couple times. It doesn't ALWAYS do it. It is mainly a concern when I am in traffic and need to move forward slightly. Black smoke also comes out the exhaust when hunting. Rich?
Is it because it was tuned with the plumb back blow off and it is expecting that air for idle and isn't receiving it? I have blocked the vacuum line going to the bov and the plumb back pipe. I haven't tried plumbing the bov back in and taking out the blanking plate. Will do that soon and report back.
R34 gt-t rb25det neo
Garret low mount on 18psi
avc-r boost controller
power fc
supporting mods
It's because of the reverberation caused affecting the afm.
The ecu sees it as more airflow and adds fuel.
Flutters are not cool enough to put up with your car running shit.
Edited by superben
I use pfc and have no probs, would like a return pipe but its a long way back to the hot side from my bov, one day I 'll have a hard line, but it works fine the way it is, no map ecu needed
Or plumb it back and live a happy life. :)
this...seems pretty simple to me mate...you changed something and it made it worse...
Now 'Im not the sharpest tool in the shed but i'd thunk the smart thing to do would be change it back ;)
Mine fluttered with an AFM, had the bov plumbed straight into the intake pipe at 90 degrees, not facing the turbo as recommended. Never had any issues
Mine didnt flutter like crazy because I softened the bov but when it did it was fine
If it flutters, the BOV is supposed to be blocked, doesn't matter if it is plumbed or not..
Yeahhhhh.... It will flutter blocked or with the BOV spring tightish. It isnt 'supposed' to be bocked
How do you tighten the BOV spring?
I didn't think the flutter would have have as much as effect as it did on my car, it is a low mount garret with a LARGE FMIC, and no forward facing plenum. So much frikken pipe work, wouldn't have thought it would have made it that far back..
 Share
    • Looked at ConceptZ HKS exhaust i just find $1000 shipping sounds crazy. and that was USD so $4400+ after AUD conversion thats the exhaust and shipping. just seems crazy is there anyone else in Aus that sells any of these exhausts?what about these will they fit they say up to 2016 though mines a 2020 just wondering if they will fit?
    • Im thinking of getting some new wheels soon so i might keep a stock in the boot some how if i can fit and secure it. i will just buy a scissor jack from supercheap aswell. thanks guys. might even see if i can find a space saver just to get me out of shit.
    • Oh also, looks like it will be 3-4 weeks before they arrive - so no coolant change until then 😕
    • @soviet_merlin Managed to find my part and get it off Amayama. While I was at it and paying 9.75 AUD shipping for a $1 piece, I thought I may as well get some other plastic clips I broke 🙈  Thanks a lot for this link
    • The point of all that for me was to get to the PDM (yes, v37 is as fancy as a haltech) which is between the battery and the front inner guard.  In there, pins 80 and 81 on connector E125 are for hi beam according to the USDM manuals. I chose to intercept the high beam signal there as it is next to the battery and firewall so it is a good place to mount the fuse/relay for the LEDs. Unfortunately because you can't access the PDM with the battery in the car, it is difficult to test those wires are correct. The fuses for Left and Right high beam are marked on the PDM cover, so I checked continuity from the fuses to those pins with a multimeter, and it seems to be right. From here I need to splice a wire into one of those 2, and run it into the cabin for a switch, then run the trigger wire back to that general location for the relay. So, I removed the driver's side guard liner to check out where the wiring leaves the engine bay and enters the cabin.  Turns out, that does not happen behind in guard liner at all....waste of time, nothing is routed through there, so that was another 5 pin clips, 4 screws and a bolt of wasted effort All of the wiring is actually run across the separate compartment between the engine bay and the cabin under the cowling...so off with the windscreen wipers after all....
