Hi guys I was just wondering if any of you know any tricks to make it harder for people to steel your car. Stuff like disconnecting wires or stuff like that so someone can't just get your keys and go. I have a r32 gtst and I often here if them being stolen and it's a worry.
https://www.sau.com.au/forums/topic/438467-theft-prevention/
I fitted a Worksbell Quick Release Steering wheel and locking mechanism (in addition to standard alarm etc)
When parked - the wheel is turned to full lock and I take the Steering Wheel off (and with me if required) - then fit the locking hub over the boss.
Should at least discourage the 'joyriders'........
Cheers
The Baron
I got mine from here:
http://www.tunersgroup.com/
There are different bosses for different cars (depending on HICAS/super HICAS etc.) so difficult to give a price for your situation.
I matched mine to a Momo steering wheel as well - all up was about $ 600.
It should be noted that 'strictly speaking' the modification of the steering column in Victoria and replacement with a 'non padded' steering wheel is not legal - but frankly I dont care ;-)
Cheers
The Baron
http://www.disklokuk.co.uk/products.html
^this!
had one for a year or two now i live in a dodge area where ive already had one r33 stolen and my brother had his ke70 stolen (luckily he got it back as it was used in a ram raid and dumped) anyway as far as im aware these are the ONLY steering lock in uk to be approved by insurers. now for anyone whos had insurance in the uk they will know this is a big deal as car insurance in the uk is legalised crime. one quote i received when iwas 19 and wanted insurance for a 1.2l renault clio was $16k.......
and no i dont sell these :P
Edited by Nii San
I'd have a word with Chris Rogers, you'll find him in the car audio/security thread. What he doesn't know is not worth knowing.
I agree.
He's about to finish work on my car and then he's taking off to Vic for some lucky sods who managed to pool together to secure his services in making their cars just a wee bit harder to steal.
This car will be the 3rd car of mine he's worked on.
For the record, he's also willing to humor any sort of security idea you might have and he'll shoot you down if it's not worth doing. Fortunately he gave mine the go ahead BUT you better have money ready. Quality work does not come cheap.
Not saying I'm rich but I'd rather spend the money on a good security installation than an exhaust + tune only to lose everything when the car gets taken. An insurance payout isn't exactly the same as your pride and joy is it? ;)
thanks for the replies guys I might look into a GPS tracker so if it does ever get stolen the cops can see exactly where the car is
...for a while until it's stripped or burnt out.
Prevention is better than a gps tracker.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
