jnr bonn Posted January 30, 2014 Share Posted January 30, 2014 hey, I have done as much research on this as I can and cant find the answer Im looking for. I need to change the head gasket on my standard rb26, and I want to put on the smallest one I can, for highest comp. I have found apexi make a 0.8mm. my question is will this be fine for a standard engine or could I have interference problems. Also does anyone know of any thinner gaskets? and whats the lowest I could go without having problems? thanks. Link to comment https://www.sau.com.au/forums/topic/438468-rb26-thinest-head-gasket/ Share on other sites More sharing options...
Ben C34 Posted January 31, 2014 Share Posted January 31, 2014 I don't think you could get any mls gasket thinner than that. Only option would be a copper gasket, you can get them in .5mm but would likely have to be custom and not worth the trouble. Not sure in clearance, I would guess and say it's ok as you are still using stock cams, but I would double check when assembling. Link to comment https://www.sau.com.au/forums/topic/438468-rb26-thinest-head-gasket/#findComment-7185347 Share on other sites More sharing options...
GTSBoy Posted January 31, 2014 Share Posted January 31, 2014 (edited) You'd have to be real careful handling a 0.5mm copper headgasket. It would fold like paper. Worse than that even. Edited January 31, 2014 by GTSBoy Link to comment https://www.sau.com.au/forums/topic/438468-rb26-thinest-head-gasket/#findComment-7185377 Share on other sites More sharing options...
Ben C34 Posted January 31, 2014 Share Posted January 31, 2014 True, it would fold like really expensive paper. I wouldn't want to handle it either. Link to comment https://www.sau.com.au/forums/topic/438468-rb26-thinest-head-gasket/#findComment-7185379 Share on other sites More sharing options...
XKLABA Posted January 31, 2014 Share Posted January 31, 2014 30 thou is as close as most recommend clearance from piston to head. .8mm would be the smallest I would use Link to comment https://www.sau.com.au/forums/topic/438468-rb26-thinest-head-gasket/#findComment-7185483 Share on other sites More sharing options...
