hey, I have done as much research on this as I can and cant find the answer Im looking for.
I need to change the head gasket on my standard rb26, and I want to put on the smallest one I can, for highest comp.
I have found apexi make a 0.8mm. my question is will this be fine for a standard engine or could I have interference problems.
Also does anyone know of any thinner gaskets? and whats the lowest I could go without having problems?
thanks.
https://www.sau.com.au/forums/topic/438468-rb26-thinest-head-gasket/
I don't think you could get any mls gasket thinner than that.
Only option would be a copper gasket, you can get them in .5mm but would likely have to be custom and not worth the trouble.
Not sure in clearance, I would guess and say it's ok as you are still using stock cams, but I would double check when assembling.
