Hi All
Not sure if anyone is already aware, but the $1000 duty free threshold (where you don't pay any GST or import duty on items costing less than $1000) is due to change at the end of this year. 2015 will see the threshold drop to $200 and 2016 it will be $0.
If you are thinking of getting parts in for a project or anything up-to $1000, it is best done this year if you want to avoid the Duty/ GST (anything from $225 upwards) plus additional cost of actually lodging an import declaration ($50 - $95+).
cheers
Dan00h
You work in the misinformation dept.
So.. anyone who buys a sparkplug or one $5 gasket will have to fill out an import declaration.
NOT FKN LIKELEY!
Are you crazy? Whoever told you this is full of shit.
Think it through, obviously you havent. Trade will die, people will get angry because they cant pay the rent anymore.
Tony Abbot would get lynched.
Perhaps "Gift" or "2nd hand" replacement part to get past regulation.
The Department of Missinformation may be correct
Need to hear and see from other sources prior to bagging out.
Current Govt is harsh.
Business wants to stop purchasing off web for all goods where Import duty / GST is NOT paid.
Could be substance to this information.
NOT FKN LIKELEY!
now, now - don't be judgemental... I will overlook your rudeness as an unmetered emotional response.
Where I work doesn't matter, suffice to say the policy is being written now. This was an initive of the former (labour) Government and one that was already in the works and commited to when the current Government took office.
I don't like it anymore than you do, as I make purchases from O/S, it will impact me as well. You will still be able to import from O/S, however you will just pay more and the revenue collected by the States (not Fed Gov).
if you are not interested, or don't like what I have to say - don't comment.
Sorry, no - gifts and 2nd hand still subject to valuation and GST/ Duty.
I'm not a big poster and don't post for the 'fun' of it. don't like what I say - then ignore it. As for a link, see my post above, policy is being finalised and therefore not yet realised. I heard yesterday arvo.
Remember when all the retailers (especially HN) were ranting about $1000 imports killing business??? This is the result and why they are now quiet! (read - they got what they wanted, which was a reduction in the low value threshold - you can google the history)
This has been a long time coming.
Will wait for the final wording before I judge.
however if it is a blanket policy it will ruin my small business.
As I mentioned above, you can still get things from O/S - it is just going to cost more for the privilege.
ahhh your typical countries...
only thing i can suggest is, if you can find them manufactured in north america, buy them from north america, as there is no duty/gst on item because of the agreement we have.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
