For sale: 1991 R32 Skyline GTS-T 4 door
Price and price conditions: $6000
Condition: good for its age, usual wear and tear,
front RH guard is slightly rippled, no RWC, but passed with flying colours 1 year ago
Contact Details: 0419 780 48three, or PM
Basic Details:
RB20DET, manual, 170rwkw, motor and box both rebuilt by previous owner (no receipts sorry).
Full Mods List:
Items in green replaced within last year
RB25 turbo, braided water lines
Z32 AFM
Nistune Ecu tuned by Racepace
GTR injectors with genuine nissan injector seals
Splitfire coilpacks
HKS adjustable cam gears
Turnflow FMIC, black core, black piping, looks legal as
Exedy Copper Fibre Clutch, very streetable, installed 3months ago
Standard BOV rebuilt to hold more boost without leaking (now blocked off, but still attached)
Walbro fuel pump
Catch Can with fibreglass heatshield sleeving on the hoses
Boost tee, running 11psi
3inch exhaust w/ Varex muffler
3inch dump pipe
Small oil cooler, hidden behind side of front bar
GKTECH braided clutch line, master & slave replaced
Slotted Rotors, Project Mu pads up front, unknown rear pads
Cusco MZ 2way diff
Driftworks coilovers, 8/6kg springs
GTR rear swaybar
Momo dished steering wheel
ADR approved race seat on driftworks superlow rail
Adjustable front camber arms
Cusco caster rods
Hardrace swaybar links up front
Pioneer headunit , sony rear speakers, ipod connector
Turbosmart eboost (solenoid broken, so use it as a boost gauge, replacement solenoids are ~$150 IIRC)
Digital water temp gauge
Aircon regassed + new drier etc
GKTECH clutch fan
R33 GTST stock wheels with Toyo R1R front tyres, heaps of tread, bridgestone rear tyres on wear indicators
New tierods ends (to pass RWC a year ago)
Rack spacers
Horn rewired + new relay
Indicator relay replaced
Fire Extinguisher
Nismo copy floor mats
Comes with the following spares:
R32 gtst stock wheels in poor condition, need repaint
Headlights
Bonnet Latch
Std caster rods
HID headlight kit
Front guard
Std drivers seat
Std steering wheel
the gauges are in a DIN slot that flips closed to hide them
https://www.sau.com.au/forums/topic/438497-vic-r32-4door-cheap/
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
