Only reason i would see the top hose not being accurate is when there is no water, apart from that, it should be ok.
You are getting a reading of Water "IN", showing that your radiator is doing its job.
Getting rid of the stock radiator was the best thing i did on my 34, its like 1cm thick :S and was not very good when thrashing the car.
Not the biggest fan of putting the temp sender in the top coolant hose I think its not the best way to do it, has anyone done anything different? What about tapping into the factory sender wire that the stock dash gauge works off? Or is that just a silly idea?
are you BLIND.... read page one
Edited by Dan_J
That would be good, apart from the problem of corrosion. You simply cannot expect an RB to not turn into a sludgy mess if you don't have a good mix of corrosion inhibitors in with the coolant.
It says on the bottle it offers excellent corrosion resistance in all metals except magnesium, or is it a bit twisted? I was considering going this way, maybe adding corrosion inhibitor will be helpful?
Yes I did, no need for smart answers there are already enough people on here. I wanted to know if anyone had tapped into the factory sensor wire.
bhaha guess its just me then... nah that sensor only reads hot/cold as stated above cant do actual temp numbers
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
