Yeah, I just wanted to gauge how much interest there was first as I didn't know how stagea owners used their cars. Thought it might have been more of a daily type of thing and not recreational.
If there is more interest and where everyone is located ill organise something.
Or should I just organise it and see whos free at that time?
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7187097
20-something stageas, a couple of muranos and one sedan hahahahah.
Last cruise was very well planned ans was a great day out.
Hopefully ill have the engine swap done and ready for the next one.
Plenty of notice is advised. Most weekends are good for me. Coming from Newcastle so i dont mind.
Edited by Howaitonaito
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7187443
20-something stageas, a couple of muranos and one Maxima hahahahah.
FYP. :P
Edited by M35woah
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7187734
Yeah I'm always up for a cruise!!!
Here are 2 photo's from our 15th anniversary Stagea Cruise (Oct 2011) and also last Septembers Stagea cruise.
it's a bit of a struggle to get the numbers together but with enough notice and a centralise meet up and cruise roote can get a fair few cars to come out!!!
  • Like 1
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188154
Mentioned to Nick on Saturday at the tech arvo the need for more Stagea meet ups, even if its just a carpark meet while the weather is still good, which he agreed with. We should try & meet atleast once a month I reckon.
  • Like 1
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188226
Guys im up for anything aslong as it involves a nice drive somewhere.
Once a month sounds good to me.
Im new to the late model import scene so im not sure how you boys roll.
Im used to cutting loose in a old school mazda, but times have changed and dont need all the bullshit that comes with that territory anymore.
Ill leave that to later on when my daughter has to put up with it in my mazda. Lol.
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188347
any one interested in buying a new stagea nm 35 vd25det for $8800?
2003 Nissan Stagea RS Four
VQ25DET
blitz BOV
blitz FMIC
BC racing suspension (adjustable)
GCG High flow turbo
DBA Cross-Drill Slotted 4000 series brake discs all around
3inch exchaust
TV system work with built-in Monitor
Regular service every 5000kms
more than 10k receipt available for history record
please contact me on o433066925
post-64093-0-67543500-1391420327_thumb.jpgpost-64093-0-28255000-1391420348_thumb.jpgpost-64093-0-22347800-1391420363_thumb.jpgpost-64093-0-71874500-1391420378_thumb.jpgpost-64093-0-77213000-1391420390_thumb.jpgpost-64093-0-17108800-1391420402_thumb.jpgpost-64093-0-28716800-1391420416_thumb.jpgpost-64093-0-28587300-1391420429_thumb.jpgpost-64093-0-41302000-1391420440_thumb.jpgpost-64093-0-77367600-1391420455_thumb.jpg
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188388
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
