Thought it was time i posted a new thread to help keep track of my progress
I'm still on my green P's (NSW) so I'm restricted to a naturally aspirated car for now sadly... since getting my licence ive gone through a few imports including a couple of 180's, S13, R32 , R33 and some subies but the one car i finally liked enough not to sell was this R34. mainly because it was so clean, unmolested and stock with no problems and genuine low k's.
It started as a 99% stock 1998 R34 GT-X Non Turbo manual when i bought it.
it was imported in 2010 and i picked it up of the first Aus owner early 2012 on 92,000 k's from Sydney, now it lives in Byron Bay NSW
I decided to change the front end because im not the biggest fan of the GT/T look and we all know the GTR look is much tougher, i managed to find a GTR carbon fiber bonnet and GTR front bar made to fit straight onto a GT/T so that was easy work and bought 25mm wider front fenders.
pre paint
During the front end conversion i picked up some cheap Tein HA coilovers (8KG front 6KG rear), removed the spoiler, picked up some cheap Work Meister S1 only 18x8+30 but there better then the 17' fakies anyday.
Once i got everything painted it looked pretty clean but needs more low and the tein's are maxed
After deciding i didnt like the black on white i bought some Wolf SP1 wheels which have a similar dished look but i went wider and black with a polished lip, (F-18x9+30 R18x10+35)
and i picked up some near new BC BR's way to cheap so had to grab them, after installing them my car is now 100% rattle and random noise free finally! and even more comfortable!
i also installed some adjustable SRI camber arms and tension rods
so far im really happy with the progress of the car, ive done some other things as well that i havent bothered to mention and take pics of to make it a better daily such as replacing the stock sound system with aftermarket speakers, 2 amps and a sub, replaced the stock coil packs with yellow jackets and new spark plugs, removed rust from inside the rear guards and arches, tinting all the indicators ect.
its currently looking like this
Added 30mm spacers in the rear for some poke
my near future plans include
- pumping the rear guards
- getting the GTR skirt add ons and rear pods to finish off the kit
- the cars also on 100,300 K's and ive just bought everything for the service just deciding to do it myselft or take it to a shop..
after that i want to get some Bride Stradia II Style seats and a genuine nardi concave steering wheel with a detachable boss to make my interior a bit nicer
hopefully have that finished by mid 2014 then to move onto the pre turbo upgrades like new bigger brakes and slotted/drilled rotors, im still unsure what im going to upgrade to, probably just R34 GTT callipers for ease and price, R33 GTST gearbox and R200 rear diff.
i plan to start the turbo conversion in december as ill be on my opens early january 2015 (i know its easier to sell and buy a turbo model instead but i really dont want to go back to a stock front end and have to start again, unless i can afford a 34 GTR or decide i can put up with a 32 GTR)
im still a little unsure of what option to take, do i just turbo my higher compression N/A engine and run low boost on a big turbo for a while or do i go ahead and do an engine swap to a DET from a 4wd Stagea and go from there? or do i go all out and go for a 26 swap? any pro and cons for either would help me decide
obviously the swap would be better in the long run, but because i have a GT-X (same 4wd as the GTR's) im wondering if im going to have trouble making one fit because there is a front diff and some of the floor pan ect are slightly different to the RWD 34's so if anyone if it is a simple swap please let me know! im hopeing the Stagea's share the same set up
ill keep the thread posted with any new updates i have on the car as it changes,
https://www.sau.com.au/forums/topic/438586-doms-r34-gtx/
  • 1 month later...
little update, lowered the car so the front bars just above 100mm and added a little more camber to the front
im now in the process of sourcing parts for the engine swap to a RWD RB25DET NEO
does anyone know if theres anything extra i would need for a NA to T conversion compared a standard RWD skyline, like is there anything physically different between the engines besides a larger sump in the 4WD, and does anyone know what happens when removing the front driveshaft and diff? like what do i need to replace them with for RWD set up ect,
any help would be appreciated
https://www.sau.com.au/forums/topic/438586-doms-r34-gtx/#findComment-7243157
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
