Really would like to turbo charge but i have a couple of questions which I haven’t been able to answer myself online.
1. Is it possible (I assume you can pretty much Turbo any V6 but again that’s why I’m asking)
2. Cost$$$
3. What other upgrades need to be done so that this turbo can be implemented efficiently.
4. Is it worth the time?
Again thanks and if anyone has experience doing this be it negative or positive I’d love to know.
The 2.5dd is a high compression motor, the only way to turbocharge it imo is to run it on e85, there is no way a 12:1 compression ratio will work with boost on petrol otherwise.
The other option is to swap in a VQ25det, which I am doing for another bloke in a few weeks. I am going to get it running on the stock ecu, with an Emanage Ultimate to help tune the timing and fuel. Keep in mind the det is a rare motor and will set you back 3k or so S/H.
Cost wise, if you need to ask, you should stop now. :P
man thats a shame, what exactly is e85? i guess i should have done some more research when i baught the car ah well what can you do, you wouldnt happen to know if the Plenum spacer Kit for the VQ35DE will fit on the VQ25DD, i mean the engine looks the same shape.
Thanks Again
Too much effort IMO. Always better off with factory performance cars, everything is ready to go. Its not just about the engine, the auto box will need work if its to survive for a decent period of time, diff may not be strong enough, brakes will not be up to the task, then you will want to upgrade the suspension, replace the flat seats... etc
Basically, once you add up the cost of parts, labour, upgrades to other bits, and fixing stuff that breaks along the way (this will always happen) all of a sudden you have spent R33 GTR money
Edited by junkie
Agreed, but then you have an old GTR and no bank account anyway. :P
All those parts would have to be upgraded in any build, factory turbo or not.
e85 = 85% Ethanol and 15%petrol = Perfect fuel for turbocharged cars.
Anything is possible with enough $$$. But as Scotty said, this engine isn't going to make it easy for you. E85 is 85% ethanol fuel. Ethanol has a considerably higher octane rating than petrol, so it has a higher resistance to detonation, meaning you can run higher cylinder pressures before it self ignites.
Otherwise, the VQ25DD will need a tear down and rebuild for lower compression. A VQ25DET engine would be ideal, but as mentioned, they are not commonly available.
If you were after more performance, as 350GT would have been a better option, there are aftermarket supercharger/turbocharger kits available.
Edited by sonicii
Ok, thanks for all the information, where would one get e85, i dont think ive seen it at regular petrol station, only ever seen 10% ethenol. anyway theres a lot to consider ( buying a different car) being one of em, but id be keen to hear of any other modes that can add something to the car, be it speed or control, shift kits seem like a great mod for an automatic car however i dont know to much about them and have only heard of the Trans Go range, which unfortunately don't make a kit for my gear box (RE4R01B) so if anyone has any experience with this gear box and gettitng a shift kit installed id love to hear about it.
Cheers
Edited by Hunter_in_a_V35_250GT
Cheers
If you stumble across a nice search engine on the interwebz called google and type in RE4RO1B you will be amazed that it is actually a R34 GT-T auto box and that MV automatics in SA make one for this box. How do i know this? Ive done it. I am the person doing the VQ25DET swap in the 250GT.
What is this Google you speak of?
I wasn’t able to find shift kits for my gearbox in the limited time that I have for searching for this kind of thing hence why I post on forums so that I may hear from other peoples experience, as I believe this is a reliable way of getting the right information. In the past I’ve learned so much from Google to only be invalidated by real people’s experience. As far as MV automatics in SA, I am in NSW Sydney, kind of a long drive, but thank you for the information, which i will now use to perform said upgrades :D. Also how much is Scott charging you to put in the shift kit, really looking at getting this upgrade.
Thanks again,
Vince
*facepalm*
I had my shift kit put in last year by a friend and former NM35 stagea owner. Scotty is doing my VQ25DET motor swap.
Ring MV automatics. What will happen is: you pay i think it was $550 in total. $100 of it is like a deposit. They send you the upgraded valve body ok. You put the upgraded one in and take the factory one out. Send them your OLD factory valve body and the give you the $100 back.
Ring around some automatic transmission specialists in sydney and get a quote on how much to have it installed.
I will tell you this right now: changes are quicker but not smoother and tend to be clunky/rough on occasion
Edited by Howaitonaito
"changes are quicker but not smoother and tend to be clunky/rough on occasion"
Does this effect the ride comfort/jerk the car on gear changes?
Cheers
It's not a commodore. :P
Of course it won't be as smooth as oem, that's why the clutches slip between gears to make it all seamless and gentle. It shouldn't be harsh at all, but I have yet to feel the MV kit.
sorry, never driven a commodore, dont expect ultimate smoothness, but it as long as it doesnt jerk or anything, i dont realyl care, how is driving tip tronic affected by the shift kits any noticible difference from full auto?
Cheers
Its still pretty smooth 90% of the time. You do feel it change but every now and then in bumper to bumper or low speeds it gets a bit jerky.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
