Hi all,
A "car won't start" thread. Hopefully you all can point me in the right direction.
Car: 1991 R32 GTR
Condition: Car turns over (cranks) but won't start.
Car died while driving. It was low on gas at the time so I assumed the fuel had run out. Topping it up with 10L didn't help, so I assumed fuel pump or fuel filter. Clean fuel is coming out the top of the fuel filter and the fuel pump primes, so it's OK there.
Facts:
  • First three cylinders have spark (only tested the first three)
  • Injectors are clicking (simple metal to injector and listen test proves that they are doing some work)
  • Fuel is pumping from the top of the fuel filter
  • ECU shows no error codes (all fine)
  • All fuses are OK
I considered AFM or air being an issue, but that wouldn't stop the car from firing up. The fact its turning over, fuel is pumping and the spark plugs have spark indicate that the ECU must be OK.
Does anyone have an idea of the next place to look?
https://www.sau.com.au/forums/topic/438667-car-wont-start-r32-gtr/
This might sound silly, but, were you driving hard when it cut out? Only reason I am asking is, if you have a big air leak, ie intercooler hose popped off, then it will crank and crank but almost never fire.
Another thing when you checked for spark, how did the spark plugs look? clean?
And try to take off the fuel line and prime the car, fuel will come out.
But by the sounds of things, I think you are not getting fuel.
Another thing, do you smell fuel in the bonnet after cranking it?
I'd be checking for air leaks or the afm wiring seeing as you have fuel and spark. Even if your fuel pump was stuffed but still providing some pressure you will get it to start, maybe not idle after that though.
Anyway, check all intake joiners Id reckon
Thanks for your input!
#@Hadouken I was actually giving it a bit of boost when it cut, so you might be on the money there.
I've had a good look around and can't spot any big holes in the air hoses around the front area of the car. Its had a Trust intake upgrade at some stage, but a few of the joiners are showing wear. No big holes though.
I'll jack it up and check the back end (turbo area) and properly look over the AFM tonight.
Spark plugs look in good condition. Have run around 2000km on them (NGKs).
I've pulled the fuel rail and injectors off and fuel is definitely getting through the injectors (the fuel poured out of the first injector when the fuel pump primed). Will get them flow tested while they're out.
I've also tried manually turning the CAS with the injectors unplugged and a little fuel in the block and it's detonating, so I'm guessing CAS or air is the right place to be looking.
I'll update you when I can.
Would that not be your problem? Fuel should not pour out of an injector that is not supposed to be open.
Good point...! I'll need to double check whether it was pouring out when priming or when cranking.
What do you mean it's detonating when you turn the cas by hand? Why do you think something is wrong with the cas?
CAS was suggested above. There is a little fuel leftover and when turning the CAS the fuel is being ignited. Detonating is probably the wrong word - its igniting with a bang and burning up the fuel (flames out the injector holes) which I expected.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
