factory RWD Stagea RS 267KW on safe tune
yellow jacket coil packs.
haltech SP2000 ECU.
full 3 inch exhaust (customised to be very quite with full power)
custom made intercooler kit that has had the piping powdercoated black.
garret gt30 turbo.
custom air filter box.
custom boost controller in centre console adjustable from 11-18 psi(made to look stock)
deatschwerks 600c fuel injectors.
fully adjustable BC Racing coilovers.
all work carried out by professionals.
80% tread on all 4 tyres, automatic, good paint, 101xxx km's, rego till march 15, 2 sunroofs, heated leather seats, electric everything, folding mirrors,
soft close boot, 17" zauber wheels (i have never seen them anywhere else), factory LSD, xenon headlights. The car is a genuine RWD, not a RS4 that has been converted to RWD.
I once dreamed about making this wagon into a track car/sleeper but i ended up just driving it for what it is and now i need a ute,
so i have finally decided to sell my pride and joy. its a very fun car without being hassled by the police all the time.very quick, quiet and comfortable while remaining practical.
I'm the first owner in Australia and i bought it with 76,xxx km's on it. never had any problems with the police. Interior is immaculate besides the usual wear and tear on the drivers seat. All 4 wheels have unfortuneatly got gutter rash (not from me) but look
repairable.
I also have a 5 speed gearbox from an R33 because i planned on converting it to manual.
$11,000 ONO
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
