Can you go into a bit more detail? BE greatly appreciated.
Have you run the MX72 pads before? What pads were you running on your old original R32 brakes?
So you have not tracked it but sounds like you have driven it plenty on the street. Do you have ABS? You have uber power so guessing you have used them for hard stops? If you have ABS does it kick in far earlier than before? What % increase or decrease do you have in pedal effort to stop the car in general driving.
LOL, lastly what BMC are you running ... sorry about all the questions
Ive driven this a few times. This was before the mx72's though, Pedal feel was very close to stock for normal conditions but the pads were shizen and didnt pull up amazingly compared to my setup but mines silly when in speeding conditions. BMC was a BM57 running ABS
I have also driven pezheads GTR with the same setup but smaller discs with Hawk HT10's and it brakes stupid well! a very slight chirp in the last 5m coming to a standing stop in emergency braking situations no ABS shuddering.. Braking feel is similar to mine which is a bit touchier than stock on initial bite (needs less pedal effort about 10-15% less distance/pressure) so it will take maybe 20 mins to adjust over a daily but then its fine. This was also ABS and BM57
For Reference roy im running 33GTR brembo's with 345mm rotors, Endless CCRG pads and a BM44 also abs but it almost never kicks in.
  • Like 1
A few seconds with the DBA catalogue tells you that the height of the R34 rotor is 53.8mm and the height of the Evo9 rotor is 43.5mm. So trying to jam the R34 Brembo caliper over the Evo rotor is likely to result in disappointment. Of course, there would be little point in doing so, seeing as you can get the right rotors for that caliper.
If you're talking about some whacky custom fitment on some other car, then you are potentially free to make your brackets so that the rotor is centred in the caliper. You could also then locate the caliper so that the 4mm difference in diameter is not so much a problem.
  • 2 years later...
On 28/04/2014 at 4:55 AM, RBN1 said:
Interesting. These are the prices I got when looking at this option:
$350 ALPHA OMEGA Evo 350mm Brembo billet aerospace alloy caliper adapter kit
$850 Pair of Mitsubishi Lancer Evo 5, 6, 7, 8 or 9 Brembo front calipers (used)
$120 Brembo caliper rebuild kit for one pair of calipers
$200 Brembo brake caliper rebuilding service for one pair of calipers
TOTAL = $1520
+cost of Discs and Brake lines.
I opted to go for the D2 8 Pot 356mm kit instead. Bigger, cheaper and came with everything required. (and it's all brand new)
Would you guys vote for D2 over brembo ?
Edited by stranger12
  • 1 month later...
    • I take it that you bought the centre to suit the GTR axles? As in there was a plan, not just somehow lucky that it worked? It all looks excellent, by the way.
    • New engine block time. Up to you whether you want to keep going down this road with this project. Unfortunately a lot of these cars are like this. The road to getting these cars into decent shape is long and not fun for reasons that you're discovering.
    • Essay time. First things first, an RB running stock turbo and boost levels shouldn't get so bad as to stall from reversion if the recirc valve has been deleted. Should get a little fluffy and annoying, but in my experience, not so bad as to stall. Of course, every car is a bit different, so it remains possible that stalling will happen. So, running with no recirc valve is somewhat of an option, for otherwise stock stuff. Atmo BOVs cause all sorts of shit, even on an otherwise stock setup. Only gets worse the higher the boost and the bigger the turbo. At that point you really need to go for a different ECU and no AFM. Rebuilding the stock recirc valve configuration is not hard. You just need a stock or aftermarket BOV with the appropriate adapter for the 2 bolt flange on the back of the J pipe, and to get/make an appropriate ~1" pipe to get the air back to the turbo inlet, and to possibly modify the inlet (if it is not stock) to take the recirc pipe back in. Not hard. Just takes some cutting and welding. Putting an R35 type AFM into the car anywhere is not as simple as just buying the AFM and throwing it in. You will also need to buy the appropriate boss that will then need to be welded onto the pipe where you're installing it. You can clearly see why by looking at the photo posted above. They are not a "simple" swap for a stocker. You can't put on in place of the stock AFM. You can put one in place of the stock AFM, if you get the mounting boss and weld it to some pipe and otherwise make that pipe piece work like the stock AFM housing. Or you can buy such an adapter, either complete with the 4 bolt flange for the air box, or without, for varying degrees of work needed to then make it fit your stock airbox or some pod filter or whatever you have going on. Oh, and the R35 AFM is not plug and play. The wiring is different, but changing that is trivial. The plug is also different so you either end up repinning the original wires onto the new plug, or you just use a short adapter. If you weld a boss to the cold side pipe, the cold side pipe really wants to be 3", otherwise the scaling on the meter can get a bit weird, but whatever the pipe size, it's not as easy as just using the (fully documented in the Nistune doco) simple method for choosing R35 AFM in X" pipe size in the software, because the scaling will already be a bit different. Anyway, all of this has been comprehensively worked through on the Nistune forums, so there is full knowledge available. I would use a Link/Haltech before I would bother putting an AFM into a cold side pipe. That's a lot of effort for a bodge. Nistune is great, can work well even at fairly high power levels, but you are stuck with the limitations of it being the stock ECU, which includes needing to use an AFM, which is not always convenient for every set of modifications. You have to have a think about what you already have, what you want to have, and decide early if you'd be better off jumping ship to an aftermarket ECU. This so you don't waste time and money doing things 2 or 3 times. Never heard of ECUmaster. Sounds like a backyard operation. If there are good tuners for it where you are, and it is a solid product, then it will be fine. We're only talking about an R engine here. Back in the day they all ran on crude nasty early 90s ECUs and they were fine. You don't need a rocket surgeon's ECU to run one.
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
    • That could be drilled, ground and welded. Would stop it progressing and leaking. But that block shouldn't be pushed very hard, as what you see there is a massive warning sign. But that fix also isn't going to happen properly with the engine in the car, and assembled. So you're looking at anew block if you're doing all that work anyway.
