I bought my r34 gt-t 5 months ago, second day i owned it i spun it out into a couple (5) plastic posts and luckily only did panel damage. Anyway after that i wondered why tcs hadn't kicked in, the car just lost traction and away i went. I checked the fuses and surprise surprise Mr Tokyo Drift (previous jap owner) had pulled the tcs fuse and the dodgy as hell importer just pulled the dash globe for the tcs warning light. i replaced the fuse and globe and all was sweet. fast forward a month ago i pull my throttle body off so i can replace the rocker cover gaskets as it is leaking a fair bit of oil past them, put everything back in and know my tcs no longer works and the tcs light is always on. Does anyone know what i did wrong?
https://www.sau.com.au/forums/topic/438694-r34-tcs-not-functioning/
TCS module is the one in front of the throttle body (R34 has 2 throttle bodies, the first one the air flows through is electronically actuated by TCS the second one is mechanically activated by the accelerator pedal.
TCS module has two plugs, one on the "front" of the TCS module and one on the "back" of the TCS module (back means nearest the firewall). You need both. The rear plug on mine has loose pins that slip out if you move the plug so double check your connections.
Why do you care? I always turn it off, not mashing the throttle is easily achievable.
The way the tcs cuts in is so harsh its ridiculous.
Anyway, check you have all the plugs on the throttle bidy and tcs throttle body plugged in correctly.
Was told the same by donovan from forced motorworx today, Will have to check the wiring and the pins for damage/looseness(is that even a word?)
Also the car has sustained $1500 in panel damage with the tcs off so i would rather it being on.
There are 3 things you need to know when you start driving a Skyline (I'm guessing nobody told you these very important rules):
1) Don't accelerate around corners
2) Don't accelerate around corners
3) Don't accelerate around corners
Don't blame the lack of TCS. Blame your right foot. Second day of owning a new car and "relying" on TCS is foolhardy. That's the nicest way I could possibly put it.
Also, do an advanced driver training day. Can't recommend them highly enough.
When i changed my rocker cover seals, the throttle body had to be removed. If you dont use the right gasket or if theres a leak in between when reinstalling, your tps will throw an error and your car will run like crap. Your tcs light will remain on too.
Hope this helps.
I ordered a new Gasket from taarks (genuine nissan metal gasket) when i did mine and hasnt leaked since. The stock paper gaskets are so brittle and shouldnt really be reused imo
Especially since i am running a new stock nissan gasket, Anyone have any ideas? It's is still showing the light and tcs is most definitely not on. pulled the throttle body again and cleaned it again, cleaned the contacts and checked wiring all ok.
  • 4 months later...
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
