Hey guys,
I recently installed a HKS 2835 GT-pro on my s1 rb25det.
I have a fmic, z32 afm, with apexi pfc and splitfire coilpacks.
I was given the impression after speaking with many people and threads on here that this turbo would feel amazing and come on very quick. After taking it out on track, it was better then the ebay turbo I had before but still didnt have an exciting power curve where it "snapped on" like i was told it would. Didnt really feel like it was coming onto boost propery until well after about 4000rpm.
On actuator pressure (1bar) it made 290hp. the power curve looked like it creeped on (linear), rather then having a steep curve which I am after.
Would running a boost controller fix this problem? or could it be another underlying issue? It was extremely hot on the day 38deg + when testing the car on track
Any help appreciated
https://www.sau.com.au/forums/topic/438697-rb25-feeling-unresponsive/
Assume if no cold side leaks.
Make sure the actuator is preloaded and tightly shut.
Test if the VCT is working.
Lastly the ECU would deduct timing depending on whats been programmed to reacting on how hot the air temp is. So on a 38+ degrees day, under the bonnet it would be very hot. See if there are any noticeably differences driving on a cold day.
Pretty much exactly what he said;
Test for boost leaks.
Test preload on the actuator, maybe even tighten it up 1-2mm.
This may be a dumb question but since you didn't mention I have to ask, have you had it properly tuned since installing the new turbo? Also what is your fuel set up? 1bar isn't a lot, I'd go for a few more psi if your fuel system is up to it
Those HKS turbos need a good amount of boost to really show what they are capable of.
On my old R32, the difference in power delivery from 1bar to 1.5bar was immense running a 2510
As long as you've got suitable injectors and a good tune, 18-20psi would transform how that turbo performs
Ak ok more boost sounds the way to go haha might look at 18-20psi
Yes had the car tuned, car has 440cc gtr injectors and walbro 500l intank fuel pump. I will have a suss for boost leaks and give it a drive on a cold day. hopefully it was just the heat making her feel sluggish haha
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
