Part Description Asking $ Pod filter with adaptor Needs new foam $30 Turbo custom intake pipe $50 Intake manifold $50 Custom turbo with internal gate HKS exhaust and Garret internals/wheels. Low mount good for over 285rwkw $550 Radiator $60 Engine mounts $50 Radiator overflow bottle $20 Aircon condenser With piping $80 Power steering pump $80 Alternator $80 Fuel pump No label but was fine for 285rwkw $80 Clutch master cylinder $50 Manual pedal set $60 Tail shafts $90 Exhaust Exhaust pipe Blitz 3in $200 Decat pipe Straight 3in bolt on $30 Wheels Impul NS-01 light weight racing 17in inc Federal tyres, 70% frt, 40% rr $700 Front 5 stud hubs $80 Spare space saver wheel $40 Stock Suspension Fronts Stock $75 Rears Stock $75 Front castor rods $75 Front upper control arms $50 Rear control arms $75 Brakes Discs Front $50 Master brake cylinder $50 Handbrake front section $40 Exterior Body shell Still complianced and registerable $400 Rear reinforcement bar $100 Bonnet latch $30 Rear bar Stock $100 Side skirts Stock or type M? $100 Rear pods Veilside $70 Spoiler - Series 1 No stop light and scratched $50 Bonnet Black - resprayed $120 Boot Black $80 Front wheel liner Front RH $20 Series 1 tail lights pair $120 Indicators Side - clear pair $40 Interior Front Recaro $160 Interior wiring loom $150 Rear seats $50 Instrument panel Standard black good condition $80 Center console with new boot $30 Headliner Excellent condition $50 Boot trim $30 Gear boot & surround Brand new boot $30 Taco gauge - 4in with shift light $60 Boost gauge - HKS with solenoid $60 Steering wheel Just wheel - needs recovering $50 Steering wheel Airbag $100 Pillar trims each $20
All parts are available for pickup in Macleod (VIC). Small things can be posted at extra expense.
Pics will be posted for each part upon request. Most things are still in excellent condition.
A slightly better format than the first:
Part Asking $
Turbo custom intake pipe $60
Intake manifold $50
HKS exhaust and Garret internals/wheels. Low mount good for more than 285rwkw $550
Radiator $60
Engine mounts $50
Alternator $80
Tail shafts $90
Exhaust
Wheels
Stock Suspension
Fronts Stock $75
Rears Stock $75
Brakes
Discs Front $50
Exterior
Bonnet latch $30
Rear bar Stock $100
Boot Black $80
Interior
Front Recaro $160
Wiring loom $150
Rear seats $50
Centre console $20
Boot trim $30
Gear boot & surround Brand new $30
Handbrake boot Brand new $10
Taco gauge - 4in with shift light Taco - 4in with shift light $60
Do you still have the power steering pump? And also would you have the thermostat housing disconnected?
Hey mate, I've still got the power steering pump in good order but the thermostat housing went with the motor a while back.
Power steering pump $65. $80 delivered.
Got the power steering resovour? If so how's the condition? Pm me
Still got it and just gave it a quick wash. Condition is excellent with no issues, see pic.
$25 pickup and I'll give you the bracket and hoses with it.
Headlights?
Sorry buddy, Already SOLD. Tail lights and clear indicators are still available on the list though...
No worries just after headlights cheers for the reply
interested in front brake disks and if u have the front washer pump (Below the bottle at the front, the one on the left).
Discs are at 28.7mm thickness from memory which is why they're priced fairly cheap with a bit of use lefy in them. I can confirm tomorrow for you.
Washer motors are sold.
Thanks
Intake manifold is still available. Top and bottom halves included. Throttle body not included.
It's not really an aging part so it's still in great condition.
What is the wheel width 17 X ? and colour
Hey mate,
The rears are 17 x 8.5 38 and the fronts are 17 x 7.5 35.
They're white and are awesome on any darker skyline (pic shows stock but previously had it lowered and looked a lot better). Have a look at the pics for the condition and style and do a search on the NS-01 impul rims for their details. One of the lightest rims you'll get.
you have pics of recaros mate?
It's currently listed on ebay but if it doesn't sell I'm happy to still sell it for my asking price here. If there's no interest it will be re-listed on ebay.
http://www.ebay.com.au/itm/111277311757?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
Edited by Steg33
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
