  • Replies 40
Posted Images
There's an oring behind that bolt. theres oil in there fot the vct to work.
Check it out and replace it.
I cant see hiw overfilling it would damge it, how much overfill are we talking?
So its a pretty serious build? Omly reason I ask is I can see a bolt blocking off a small coolant line in the photo ;)
I doubt the leak has anything to with revs or overfill. Its just a leak.
no seal between the bolt and the cam. Should have the bolt with a washer behind it. Then a spring and plate with o-ring on top of the bolt. Ive had that one off quite a few times when building my engine
Id expect a little bit of leakage past the bolt but nothing major. How come the cover is off?
The neo engine has a different vct setup that uses an oring behind a bolt to seal, which is what I was thinking of.
Pre neo is different as 89cal pointed out 2and the image I posted shows that.
You are missing the cover and the seal.
wait you're missing the cover, spring, seal and those 4x 6/8mm?mm bolts
that's why it looks funny, also if that's the case how does your VCT function properly? I'm sure that spring in there to shift the cam sprocket
