  • Replies 40
Posted Images
All im missing is the cover plate though, if it wasnt run before all thats doing is holding the oil not fixing the leak at all....
No, you're missing a myriad of things, go look at the service manual page provided in this thread
yes that entire area filled up with oil, when I took mine out (twice) to do my timing belt and seals, etc.. oil dribbled out.
If you removed the entire VCT sprocket/gear you'll understand how it works.
Im so mindf**ked right now, i understand from after writing the thread im missing parts, but why has it started to leak now, this is what im confused about. ill dig up some pics because maybe i never realised it accually had it on. maybe someone took it off, not me onbviously.....
is that a spring washer? It doesnt look right. The bolt in mine was a flanged bolt (washer attatched to the head basically, the parts pic shows it in this style) with another thickish washer under that.
If it is a spring washer and a normal bolt, someone may have done a dodgy when putting it together.
And because I'm in a nice mood, part numbers and pricing (from Amayama)
Spring: 13072-45V20 ($1.78)
Gasket (O-ring): 13037-75T00 ($1.51)
Bolt: 01436-01011 ($2.92)
Cover: 13083-75T00 ($6.71)
Not sure if Nissan Australia will stock these but worth a try. It will be more expensive locally but
