In their thread they said they were making them in NZ.
China is more likely to make robotic stuff that can pump out thousands, hence all the stainless jobs.
I'd probably buy a china steampipe manifold if they made them lol full-race are robotically welded, and I'm sure china could replicate the tech lol
My mate had an exhaust wheel destroyed on his brand new 6262 from 2 pieces of weld about 1" long which came from inside the manifold where the collector had been welded internally. It was cleaned out thoroughly numerous times before it went on the car but these were obviously right down inside a runner. Better off spending the extra coin on a decent manifold. It ended up costing my mate more in the long run
i am nearly 100% certain these are imported from china and sold from there
probably through Alibaba or Aliexpress, because they look identical :)
Looks familiar?
http://www.aliexpress.com/item/Top-mount-turbo-exhaust-manifold-for-Nissan-Skyline-RB20DET-RB25DET-3mm-mild-steel/1052835806.html
Wow looks like the same turbo kit Hybrid Performance sell too?
http://www.aliexpress.com/item/WSRacing-turbo-kit-for-Nissan-Skyline-RB20DET-RB25DET-Upgrade-430hp/1052572162.html
  • Like 1
you need your eyes checked then!
i would only like to hear from people with ACTUAL experience with Hybrid Performance low mount manifolds (RB20-RB25 IW)
not knob jockeys with hearsay!!
LOL WHOA who are you calling a knob jockey?
These are people giving valuable advice in the form of their opinion, and they are trying to help you make an educated decision.
If its not the opinion you're after just go buy the manifold and axe your turbine wheel in oblivious happiness. Don't come pretending to care about the truth.
My friend bought one, we saw the insides and he then sold it back on eBay and now runs the stock manifold
then thought, hey let's go on alibaba and find one, turns out it's identical (just different photos, in different lighting).
Up to you buddy.
Up to you buddy.
Johnno the knob jockey...stop trying to help.
Has anyone been able to get in contact with hybrid lately??
I've sent him two pms this week so far and he hasn't replied to either...
I was going to buy one untill reading this... Does anyone know where to get brae manifolds & how much they are?
hit up Stao from Hypergear he should be able to point you in the right direction.. they're roughly the same price as 6Boost give or take.
Ahk if their around that price range I won't bother, I think Rex kellway are around $500 from memory
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
