Or maybe the arachnophobia until now was just an elaborate ruse, all for this moment...
Still, this blows, man :/
Maybe it was Aaron and his arachnophobia all this time served for the perfect alibi.
Not good, get some cameras up ASAP, we have them on all the time.
We have a lot of customers also over, i ended up moving all our GTR gear to another family members house after seeing the same car with tinted windows slowing down and eyeballing what was inside the garage, customers also were looking at everything, it was just a matter of time.
A worker at one of our suppliers was telling me a few weeks ago that someone cut his roller door open with 3 cuts, enough to climb in and help himself, someone disturbed them and they ran off, police know who they are but cannot find them, this is in the north western suburbs though.
Trust nobody, parts are big $, hope you catch the theiving prick and give him a taste of it.
Thanks guys, looking at camera setups at the moment, JB wanted $900 for a pissy 4 camera set, looks like I am going Ebay.
Already have the chunky padlocks to fit ,rather than the padbolts.
Bunnings sells swann security systems, (though when I was looking at them all the boxes were empty because thieves like to steal them ) or try Jaycar...or you can just get a card that bolts into your home PC if you have a spare PC that doesn't do much...
Swann camera setups are good. Got one after some scumbags broke into my garage a while ago and took all the tools that took years to collect, then ransacked the house for good measure. I'm still pissed about it
Watch out for IR cameras with the built in LED's, they can help you see in the dark but are sort of carppy on the night image after a while, try to get cameras and a seperate IR spotlight thats pointing in the area your trying to cover.
Bought a cheap 4 hd camera setup, now to find a 2tb sata2 drive cheap. I will have movement activated flood lights soon, should help with the night vision.
At least I will be able to rewind the video, to find lost tools when I misplace them. :P
man whats wrong with people :/
ill keep a look out up here.
thats why i stash all my nice parts under my bed.
have had people i know come over and all they see is crappy parts and seem uninterested in everything.
that was my idea. take credit for it.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
