Located in South Australia, Pick up welcome, happy to post anything interstate at buyers expense, prices are negotiable but be realistic guys & girls these are all genuine items no fakes or copies. PM, call or sms 0402072466 thanks :yes:
Genuine 100% Titanium Power house Amuse R1 Titan Cat back exhaust, direct bolt on for R33 GTR & Gts-t, with a little modification it will fit onto R32's & R34's. 90mm piping diameter & 130mm tip. this exhaust cost me $3000 it is less than 4000kms old. weighs about 6kg, i had an AM performance 400mm mid muffler/silencer put in less than a month ago that cost me $650...its a straight through design so it does not change the flow at all! On a top mount turbo'd RB25 with a hi flow cat at 4000rpm the exhaust used to measure 105db but since the muffler its now just over 91db... sounds very tough & unique, i still have the piece of titanium we cut out so if someone wants to make it ridiculously loud again they can just have it welded back in. Price is $2,100 O.N.O pm call or sms 0402072466 (ps The pictures are before i had the silencer put in)
post-30634-0-80015900-1391659814_thumb.jpg post-30634-0-71028000-1391659822_thumb.jpg post-30634-0-27508900-1391659830_thumb.jpg
post-30634-0-86713500-1391659838_thumb.jpg post-30634-0-70051500-1391659847_thumb.jpg post-30634-0-77386700-1391659871_thumb.jpg
Genuine HKS 3037s (external gate) 56T .73 Rear Housing, Its just under 5000kms old & was ceramic coated by Ceramic coat Australia in Richmond S.a It flowed over 300rwkw on pump fuel very good balance between power & response, price is $390 O.N.O pm call or sms 0402072466
post-30634-0-34476400-1391657199_thumb.jpg post-30634-0-44417200-1391657212_thumb.jpg post-30634-0-69486500-1391657221_thumb.jpg
Genuine pair BRIDE Brix II seats with Bride RX Type rails, less than 5000kms old, in absolute perfect condition always treated with the utmost care & meguiar's leather conditioner, No rips or tears at all. will direct bolt into every R32 R33 R34 model skyline except for R34 GTT's these seats & rails cost me over $2600, full reclinable, not willing to separate so please don't ask these seats are now discontinued so they are very hard to find in this condition Price for both seats & rails are $2100 O.N.O pm call or sms 0402072466
post-30634-0-59851500-1391657093_thumb.jpg post-30634-0-99155900-1391657104_thumb.jpg post-30634-0-91649000-1391657115_thumb.jpg
post-30634-0-24776800-1391657126_thumb.jpg post-30634-0-61640200-1391657137_thumb.jpg post-30634-0-23787100-1391657149_thumb.jpg
post-30634-0-63160200-1391657167_thumb.jpg post-30634-0-48864100-1391657178_thumb.jpg
Genuine pair of Ikeya Formula front upper camber arms (negative type) bush not pillow-ball, these will direct bolt in to R33 GTR Gts-t's R34 GTR & Gtt's, less than 9000kms old, not willing to separate so please don't ask price is $285 O.N.O pm call or sms 0402072466
post-30634-0-35447500-1391657235_thumb.jpg post-30634-0-34683200-1391657247_thumb.jpg post-30634-0-42908400-1391657255_thumb.jpg
Genuine Nismo Fuel Pressure Regulator, came off an Rb25 R33 with an aftermarket Greddy 11mm rail, will fit a bucket load of different Nissan models about 15000 kms old very good condition Price is $80 O.N.O pm call or sms 0402072466
Genuine Nissan R33 Gts-t front Tie Rod Brand New, will come with a genuine Nissan crush washer & the wire to hold the rubber boot in place, that's how i bought the kit from Nissan. Price is $60 O.N.O pm call or sms 0402072466
post-30634-0-38892100-1391662373_thumb.jpg post-30634-0-78133700-1391662384_thumb.jpg
  • Like 1
Dam those seats are sexy :3 good luck with sale man ! wish I could afford them hehe
Thanks a lot man appreciate the compliment & well wishes! Hope they go to a good home
Gts-t front Tie Rod will fit gtr33?
Hey mate not to my knowledge it won't, but I'm not too sure......anyone on here knows a definite answer please let us know
Damn GTTs!!! :rant:
Wish they were compatible lol
Lol doesn't make sense what Nissan did! U can always buy some bride rails to suit gtt's & problem solved :P (not that dear of nengun)
Ps awesome car man I followed your build for a while there! I hope to meet you at an event someday & chat about everything skylines!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
