  • 1 month later...
  • Replies 293
  • 1 month later...
This was the bad boy I got off of Noel. I have found another and it is on its way from Japan.
Got my car back from the smash repairers. Like most insurance jobs. Dodgy.
No power to headlight. Coolant leak. Over charged me. Stuff missing. Paint chips. Over spray last but not least. A miss aligned headlight, and they just masked it with spacers.post-108324-14410185130718_thumb.jpg
And the headlight was mounted by one bolt. The ones in the headlight panel. Drilled through
Edited by cowdy
  • Like 1
So I got the studs from kudos a few days ago and ripped it apart on Wednesday. 2 studs were broken and missing and 3 more were broken but still sitting in. post-108324-14425872833866_thumb.jpg
When undoing the turbo the only thing holding it on was the locking tabs. The nuts all came off by hand. No snapper needed to even crack them!
So I tried to get them out Thursday wit no luck. So called threadtech and this morning Craig came and got them all out in about 10 minuets. Money well spent!
So this afternoon after work I got stuck in and got it all done. New studs. New turbo new exhaust, gave it a service and new Coolant. Finally last new cam cover gaskets (been needing them for about 6 months)
post-108324-14425874464773_thumb.jpgpost-108324-14425874642134_thumb.jpgpost-108324-14425874773995_thumb.jpg
Finally locked the door at 12.30 and said I need to get off my feet since being on them since 8am the morning before
The car is at work cooling down and I will let you all know how it goes tomorrow
Had one little hiccup. New washers for the oil feed on the turbo were leaking so I grabbed the old ones. Gave them a clean up on the wire buff and stuck them in. Worked perfect and no more leak!
  • 1 month later...
Had some more fab work done and had a new intercooler pipe done up and intake pipe and intake box
Having some issues with a flat spot since the new turbo I am pretty sure it is cool packs breaking down as I have had a set do that before. After the pipe work it was three times worse so took the boost bleeder off so I'm only running stock boost. It has settled down a little but is still there
So I have a new set of coil packs on order :)post-108324-14455931204879_thumb.jpg
  • 6 months later...
Been a while. Made some progress further to my goal.
Now have a pro sport boost guage
Ls2 coils and mil spec loom to go with
Turbo smart 800 v2 fpr
Got a raceworks fuel rail
And I will be changing pumps from a dw300 to a walbro 460
Changed ecu options going to be using a vipec v44 which I now have :)
And got a new laptop for using in car :)
Also have all fittings to fit said rail and a flex fuel sensor
All I have left is a few things to wire in
Get some injectors
For everything and get it taken in for a tune!
So bit of drama the other day. Serviced my car and noticed an oil leak from the new turbo post-108324-14645180265163_thumb.jpg
Called gcg on Friday and they said yeah they will warrant it so take it out and send it back
Pulled it out Friday night and noticed this crap https://youtu.be/b7WaoPU_L3k
So I will speak to them Monday morning about it and see what to do
I have been on a bit of a parts hoarding stage
I now have all the fitings, hoses and major parts needed to finish my car
Got some raceworks 1150cc e85 injectors, continental flex sensor, buying a injector sub loom so I can put plugs on it instead of using adapters getting the walbro pump next Wednesday
So nearly there
After sorting out this turbo issue I will see how that goes and then get some money together for tune!!!
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
