  • Replies 293
Sorry about the gold tinge to the second pic it's my case.
So that's just the bias it set up a t10 holder cable tied into place. Wires run from both and joined into one cable
+from car goes to a fuse then switch then out of the switch goes to the 2 lights then back to single wire and earth.
-----|_|---/_----/-------0--\______ -
\_____0__/
  • Like 1
Got my exemption :D so happy that I ca drive it again.
Car is booked in for an alarm install with chris Rodgers :)
Should go nowhere after that :P
Going to take it out to happy laps this weekend and maybe put in out on lakeside and se how it goes. That's a big maybe
Window motor and reg is in. All works. Took the car out to lakeside today and watched the happy laps :)
Got home and figured out a way to pump up my rear left tyer (valve is to short in the gtp's so I have to get a valve extender) had to use a bike pump.
And sold car parts to nick (#@Captain Natro) and another guy :P
Glad you've finally got the exemption through! Bring on the fat lapping....
Clear side indicators look so much better. I remember I first bought tinted ones and thought they were ok, but then once i got the clear ones i realised how much better they look!
Whats next on the modifying list Zac or just some enjoyment for now?
I have had my enjoyment in the past few weeks. I'm going to out my 4.11's back in the 4.3's are a bit crazy. I'll keep them for skid days :P
Then after my alarm install I will be looking for sway bars and bushes. Later on shocks and springs :)
Theeeeennnn
34 turbo and fmic piping or intercooler kit, fit the intercooler and leave that for a bit. Then I will be highflowing turbo and fit that and send the Ecu off to have the mods down to suit r33 and once that's done is done I will get base map. Install it amf and 34 turbo and then send it off for tune
This last step will be in the last 3 months of p plates and just leave it sit till I'm off them
So the next few little things I will be doing. I will be installing a volt guage.
Disabling the speed lock on the passenger side.
And take this window regulator back out and switch the motors. This one dosnt line back up properly so it is going to tare my seal. I do not want that haha
Put some new bolts in the guards and headlights and stuff will post pics tomorrow
Had one of the gtp's go flat on me today, the valve is leaking through the seal. So I went and got some tyers put on my stock rims today and I will put them on tomorrow photos to follow
Stock tyers on the rear
Why the wheel was leaking
tire being re-fitted
And didn't get any photos of the guard bolts but will do tomorrow
This thread used to have a lot of interest :( it was motivating me :(
Quiet disappointing to see it all go away
And the worst part is you guys are missing out on this
Trust return flow intercooler got it for $150
Straightening fins
painted black looks gloss but dries matte. It's drying over night and tomorrow I'm painting a
In red
Got them all cut out will just be spraying it on tomorrow
And re painting the pipes black
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
