Hey guys got a problem my car didn't make the power I think it should have made.
Rb25det s1
Gt3076r .63 rear
High mount manifold
50mm wast gate with 14psi spring
800cc injectors
Bosh 044 fuel pump
Turbo smart fpr
Upgraded coil packs
Greddy copy intake.
3inch straight exhaust
Blitz dual solenoid boost controller
Microtech Lt12
I only made 296rwhp was the best run of the day at 18 psi
Seems low compared to others iv seen on this site?
Also I did notice that boost drops off from 18 nearly back to 14 at the top. Fuel and air sitting on about 11.6 . Any thoughts?
Edited by DriftSquad
You will need a stiffer spring in the gate imo, and the .63 rear won't be helping things.
Can you get us some pics of your setup? Was the exhaust dropped on the dyno?
I didn't get the chart as I was not happy with the tune. Tuning was done at Godzilla motor sport. On his dynonamics awd dyno
and tell them to send you the tune file
I have a feeling the tune was shit house, also because it's a microtech lt12.. they're so clunky to tune with.. 2x tables to do essentially a single table can do.
I'll ask him to email it to me. Marks pretty good tuner. I mean it is a microguess lt12...
We had to pull some timing cuz she was pinging on boost. He said he thinks the .63 housing is to small
Not sure it's just a stainless manifold with gate mounted to it. The power I Made is not much better then a standard rb with a tune..
If you had bought a decent standalone and left the FFP, stainless manifold, fpr, boost controller etc off the list, you will have had more money to spend on finding the issue on the dyno.
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
