what said above is don't under estimate OEM, until you reach the limits.
Don't buy gear that's unnecessary for the power level wanted
Not sure what you ment buy that, the car has had a lot of work even before the upgrade. I had already maxed oem before I spent money on the turbo injectors computer intake and manifold so that makes no sence.
Yes it has an front mount intercooler I just didn't list it. Prob got a few others I haven't said
What manifold is it running? Are you getting adequate flow to the wastegate?
IE its not a china stainless manifold with a meter long WG pipe is it?
What do you mean max it at? We had flat 11.6 afr. 18 psi and it slowly dropped back to nearly 14 psi may that have been my problem?
I can't remember when or how much the microtech was its a plug and play with hand controller.
Not sure if it's a china manifold. It could be. It's got 2 pipes that join the collector and joint to 1 pipe to the gate
You bought crappy parts and thought it would add to your power goals. Many others have done the same thing, don't feel like we are singling you out. All you needed to max out the GT3076 was a 3 inch exhaust, turbo, decent modern injectors and a Walbro 255. A decent ecu (adaptronic etc) wouldn't have cost much more than the Microguess.
you mean micro-iceage/Neanderthal? lol fuark man I road tuned a car with it before, I was so close to just calling it quits.. it's was built by morons.
1x table is just RPM vs. ignition (yes there's no load) and there's another table for load and how much ignition you would like to shave off.. LOL..
you said " I had already maxed oem before I spent money on the turbo injectors computer intake and manifold so that makes no sence."
So I ask again, what did you previous setup max out at? and what did it comprise of?
Guys are making 200kW with stock injectors/manifolds/turbo/coilpacks etc.. with just more boost & ignition/fuel maps optimised (either through a toshi remap/Z32 new ecu, etc.)
My last set up was
Stock turbo
14 psi
Cooler
3" straight exhaust
Coil packs
Blitz boost controller
Bosh 040
Tuned remped computer
Can't think of anything else, made like 186 kW I think
I don't think most of my parts are cheap and crappy.
Garret gt3076r .63
Pro gate
Denso 880 injectors
Greddy copy plenum, been machined flat. So just like a genuine
Unsure of exhaust manifold but my friends vl has the same one making 589hp on 20psi
Blitz duel stage boost controller was told it was great!
Microcrap lt12 well I took some bad advice on that one
Turbosmart fuel reg
Bosh 044 pump off a relay for 13.8v
Can't remember what else.
The suspension and underbody is well ajustable everything. The car had cost a lot.
I think I'm about 70hp shy of what I thought I was building the motor for.
Mark did say the air temp adjustment prob was not in the engine bay and may have robbed me of a few hp?
The stock manifold was cracked and old and not a high mount set up and needed to for external gate.
Boost controller is a blitz duel stage. I can send a pic if u like? I had to change the fuel pump on the dyno because the old 040 let go. It's now a 044.
Maybe I just have a really tied motor. I'll do a compression test soon.
I know the microtechs are not the best but I didn't think it would cost me this much. Mark said he thinks the .63 is to small and that's y it drops boost off back to wast gate spring pressure.
I thought maybe some one might have had this sort of issue in the passed. I pretty much just copied someone's setup n thought it would work so I dunno what about a boost leak some where?
I was going to ask what the condition of the engine is like. Do a compression test and see if you can work anything out.
and you definently need a printout of the dyno graph. That will tell alot more of the story
not all 3076's get 300kw on 98, mine with gtx3076 0.83 external gate was limited to 278kw on 16psi, it just wouldn't take more timing so a 0.63 would of been even worse,
mine would rise 10kw per 1psi, so with 18psi you might get 265kw which maybe quite normal.. mine was running 175psi each cylinder which I thought might of been the reason,
run some E85 and you might find it will smash thru 310kw
You should get more power then that - mine is 284rwkw but with a little bit more timing I have gotten it to 294rwkw however on some loads would ping so safe at this.
This is just on straight 98, my gate is welded on the back of the turbo housing.
Similar support mods, obvisously different ecu and tuner but for your reference:
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
