Selling my Silver 34 GTT, Series II, RB25 DET Neo. My daily driver - some extra Details HERE
Very recently Highflowed (GCG2871), Nistuned, Lowered, Metal intake, Pod, FMIC, Splitfires, Walbro FP
Clarion Double din stez with 7" screen 10" sub in booty
Tread is RSR's on 18" Gold Volk GTC's
Looks and goes great guns
245rwkws on 16Psi
A few months ACT rego left - RWC not an issue. (Pod may need to be removed for Tfr to Victoria)
140k Genuine km's on the Odo
No accidents and all receipts available to buyer.
Bad points -
Steering wheel needs recovering or replacing (IMHO)
Driver seat bolster worn. Has 100% Australian wool black seat covers :thumbsup:
PM me if interested - Cheers, Richard
- Some below pics prior to lowering with Lovells and a few at the bottom after (stock springs go with car)
- will take more specific pics on request
Edited by Sinista32
Edit - has new ACT plates due to a fuel runner stealing one a few months back
- front grill is now balck with Nismo badge attached and silver S removed. looks heaps better
Edited by Sinista32
  • 1 month later...
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
