Hey guys,
I've got a bit of an issue with my set up:
r33 rb25det,
hypergear 21U highflow, 20Psi E85. Made 306kw on the dyno with wheelspin.
I run a single GTR blow off valve recirculating
anyway Toshi said during tuning that it feels like there is a small boost leak and it does feel a bit laggy in lower gears. I pressure tested the system and it holds very well, I used soapy water and the only leaks i found were above 10psi and that was from the oil catch can. I pressurised from the intake pipe to the crossover pipe so both sides of the BOV were pressurised.
I'm wondering if when I'm coming on boost maybe the bov is leaking into the recirc pipe? Has anyone had issues with this before? my GTR valve is in pretty average condition visually.
I want to make a plate to block it off and hopefully that will improve response. This shouldn't affect the tune right? seeing as it recirculates after the AFM (I have a wideband I will be checking anyway). I don't plan to run this set up as I don't like the idea of hectic flutterz and stalling etc. I'll replace the valve if I have to but I won't get ahead of myself just yet.
Also, I've read about people using beer cans to make a block off plate. This sounds easy but I'm not sure how well a thin piece of aluminium will hold up against 20psi and I certainly don't want that finding it's way into the engine. What do you guys think?
sorry about the essay, thanks in advance
-Tim
https://www.sau.com.au/forums/topic/438786-leaking-blow-off-valve/
It will affect the tune if the turbo is more responsive obviously, but blocking off the bov with a bit of coke can is a good test to see if it's leaking. Anything is fine, 2mm alloy would be even better but it's only for a test.
Hey Tim,
Perfectly fine, no way the can will enter the pipe if you make it the same size as the stock gasket with the 2x holes for the bolt..
Tune wise no change, except on decel, you might get the occasional pop or near-stall as it will richen up the mixture
okay wicked but it won't affect my AFRs by much I'd hope. Ill keep an eye out anyway and keep you posted.
If I'm up for a new BOV I would prefer to spend the money on a brand newy. Are those Turbosmart Kompact plumbback valves any good? I'll find a link:
here http://www.turbosmart.com.au/product/kompact-plumb-back-nissan apparently these bolt straight up.
mad okay thanks for the input lads I might have to 'modify' a GTST valve with a socket and a hammer haha.
How do you change the spring tension in the TS model scotty? Glad to hear it has lasted so long, makes me feel better about buying one seeing as they are $160ish compared to $15 for a 2nd hand GTST valve
Edited by Blackkers
nothing wrong with the stock one man, I ran 1.3 bar into the factory GTS-t one for years.. however it was squished in a vice (to preload the spring more) haha
You could have picked up 2psi for free with a Kompact.
You need to buy another (softer) spring from TS, and the top screws off. Most guys don't like the little flutter they make and want the softer spring.
haha VB it was, slight gain in response. Slight but definite. Only noticeable in 1st,2nd,3rd. It feels like its spooling much quicker. I guess the spool wouldn't change but more air is entering the motor. anyway I'd call it maybe 400rpm difference in 1st gear
AFR's didn't change as far as I can tell and no weird noises. Well other than the sututu which sounds pretty loud with a pod filter and your metal intake pipe.
I'll remove the plate and add a new bov to the list of things to do before getting a touch up tune.
touch up tune was on the to-do list anyway due to the 255 pump being maxed out and having to increase the injector duty to maintain good AFR's in the top end. The pump can't keep up and fuel rail pressure must be dropping I guess; I trust toshi's judgement but I don't like the idea of 100% duty on the pump, what happens if my alternator shits itself and suddenly the voltage across the pump drops to 11.5
thanks for your input
Edited by Blackkers
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
