Mate I've just been through this exact same problem over the last few months with the bosch 023 (040 big bro). First time pump last 3months but got noisier and noiser. Must've got a bad batch of fuel or something because it started leaning out big time and groaning badly. Fuel pressure dropped 2 bar. Took out the pump and the entire screen was filled with minuscule particles. Bought a new 023 whilst cleaning the old one and testing. Fixed the problem for about 1.5months then did the same thing. Exact same problem but I have suspicion my 'Submersible fuel line' was not what it was supposed to be. Replaced old pump, Was fine for 3 days then the same thing happened.
Long story short. The bosch intake fuel pumps are incredibly sensitive to debris. Seeing as they only have a screen mesh and no removable filter they are restricted to a flat surface area that once blocked, cannot allow sufficient fuel to be delivererd to the system. If you have a fuel pressure regulator with a gauge, check your current pressure at idle.
Solution - Install a walbro. Your current power figure could get by with a 255lph but if you plan on chasing more power (I have the same turbo @ 300rwkw) go for the 400lph to future proof. They're smaller, more efficient, easier to fit and have a larger surface area of pick up due to the removable filter sock.
Edit: Forgot to mention - I only fitted the walbro 400lph pump on Tuesday but the pump is dead quite, fuel pressure is up around 3bar idle (vacuum off) and it's the smoothest it's been in months. Will be pulling out the pump in a few months time to asses the sock as I still believe there's debris in my tank.
Edited by Reflector
From what I've read thats an E85 specific pump. I don't have access to that fuel unfortunately.
There are petrol specific versions which are cheaper, I think I can get one for $160. Then there are the e85 compatible version which is suitable for both 98 and e85, $200. These run a sealed power plug.
No worries mate. Also something else to consider - Due to the walbro being smaller and having a 45deg filter sock, it will fit a lot nicer into the cavity of the fuel tank allowing pick up a little further down the tank than what the bosch pumps permit. I've always commended bosch for having quality products but this time round, I can definitely say for an R33 Skyline application - Walbro > Bosch.
Edited by Reflector
Changing the pump should do absolutely nothing if you're upgrading pumps. Keep in mind you'd want to check your wiring when using a 460L - I've had wires melt twice due to some shoddy worksmanship on mine.
do those E85 460's really draw 20A?
I wouldn't trust the factory connections on the fuel lid with that kind of current. I'd be punching through the lid, feed some 25A wire and hot glue it. Does anyone bother doing that?
depends how much boost you run, as the fuel pressure increases yes it will hit past 20AMPS
I had the factory 15amp fuse blow on me (when I first installed it), now I'm running a 25AMP fuse, through 2x relays & a 50W 0.3ohm resistor to mimic the FPCM
As long as the connections are clean you should be fine.
Not sure I would trust hot melt glue, but the lid is fairly easy to re-make in alloy, then find some proper high current sealed plugs, or sealed bolts for connection like I used. Good opportunity to run teflon lines too.
  • Like 1
Had a similar problem recently at a track day with a Bosch 040 in tank pump, after about 3 laps I would get pretty bad fuel surge when revving out in a straight line even with a full tank, wideband showed it lean right out when this happened (up to 19 AFR). Also the fuel pump got noticeably louder as the day went on. Possibly due to the mesh filter being a bit blocked but I just replaced it anyway with a DW200 pump. I haven't driven it hard yet but noticed at idle fuel pressure now sits around 38psi whereas with the 040 it was about 30psi. I should be heading to the track on Monday so I'll report back if it fixed the problem.
New fuel pump seems to have fixed my surging issue.
my 32 ate 2 bosch pumps,
some debris in the fuel kiled one randomly, usual noisy symptoms, surging ect.
replaced it and all was fine for a bit then that one went too.
i had miniscule particles in the fuel, took the tank out and had it cleaned, new pump (different brand) and all was well.
i couldnt even see anything on the mesh but its the tiny bits that got into the pump. kills them fast.
be wary of sticking another pump in, what killed it last time may take another out. check your fuel and tank, at least flush it, all new fuel, new fuel filter too.
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
