Contact details:
Number: 0422 595 214
Email: [email protected]
What im selling.
Im selling my manual 4door R34 GTT
Price: $10,000 Without RWC
$11,000 With RWC
Kms: 180,000
Plates not included
It has:
-Shockworks Coil Overs ( 3 months old)
-FMIC
-After market alarm system with central locking.
-Half wired sound system (ive been a bit pre occupied) With a touch screen double din dvd player.
- HKS SSQv2 BOV ( will be removed for road worthy)
- K&N Pod Filter ( will be removed for road worthy)
-Turbo smart Boost controller ( will be removed for road worthy)
Not installed but will come with the car
-Apexi Power FC with hand controller
-Stock shocks and springs
-Stock BOV
-Stock Air box & Filter
Reason for selling: I bought a new car.
Pictures.
1462835_10152015813604718_433645866_o_zp
With coil overs, all other pictures are on stock springs and shocks.
The Flaws.
Rear Passenger side door wont unlock ( module has seen better days )
Slight boot rust near the break light
Front speakers not wired up.
Thanks for reading and if ive missed anything please let me know so i can update the post. Thank you.
https://www.sau.com.au/forums/topic/438805-vic-for-sale-r34-gtt/
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
