car is an r32 4 door rwd turbo
car was originally an n/a auto but the na engine had issues (used to overheat) so i bought a turbo engine and manual gearbox (only converted a month ago)
still has n/a brakes, also car has abs
17x9 advanti wheels with 235/45 tyres
car is lowered with kyb struts and unknown springs (the shocks are kyb hill climb
one rear shock is stuffed but with supply with a pair of coilovers for right price
has aftermaret boost, oil pressure and water temp gauges
all the water hoses have been replaced on the engine
car runs stock boost hasnt been boosted past stock since ive put the turbo engine in
gearbox crunches 2nd (was like that when i bought the engine conversion)
doesn't come with the cd player (its nothing flash anyway)
one of the rear windows doesnt wind down, never has since ive had the car never looked into why it doesnt cause i dont sit in the back seat
new exedy sports tuff clutch (doenst even have 1000k's on it)
speedo stopped working when i put the manual/turbo engine in, maybe the sender is stuffed in the box dont know
has hicas lock bar and adj rear camber arms
has 600x300x76 fmic
bigger exhaust i think 3inch not sure haven't really looked but its got a note
car sometimes missfires under load and then clears (does this most of the time) could be a vaccume leak could be a afm could be coils im unsure and dont have the time to fix it, will supply with a set of new bcpr6es11 spark plugs
also runs rough on idle sometimes
aircon works but the aircon compressor sounds bad
turbo is noisy but am supplying another stock unit with the car
car is $6000 Ono, will sell it a few hundred cheaper without the wheels byo wheels
will sell with rego if buyer gets a rwc within a week
paint isnt too good
the car is what it is
contact sms or call me: 0423 413 431
reason for sale is cause i have too many cars, not interested in swaps only cash
https://www.sau.com.au/forums/topic/438807-bris-rb20det-r32-4-door/
bump it up, leak is coming from the inlet manifold gasket so im gonna change the gasket and itll be a goer or make an offer as is and ill supply the gasket
nope cause it doesnt seem to blow through there, its only 1/4 inch to big its just too long and i havent been stuffed to cut it down and its clamped tight
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
