not sure why I bothered for you, as you could of done this yourself...
this was the result I found by using the search function, think of it as google for SAU, or infact I could of just used google and mentioned site:skylinesaustralia.com, would of given me the same results...
or you could of even gone to your car pulled the iginition area apart and worked it out for yourself, all of these methods are piss simple...
but its the weekend, its a nice sunny morning and I have a nicely made coffee here which just happens to be at the perfect temperature right at this moment, so its perfect timing for you, me seeing this thread...
http://www.skylinesaustralia.com/forums/topic/330803-blue-led-dash-climate-screen-and-clock/page-2#entry6187697
Posted 14 January 2012 - 08:49 AM
'wilderboy', on 21 Dec 2011 - 10:19 PM, said:snapback.png
how did you change the Key illumination ring???? iv dont my dash ac clock and sunroof light and interiour light and i just dont know how to change the Key illumination ring
i was wondering if theres a straight swap out or soldering and shit
straight swap man. its a t5 bulb. the ignition surround should just pop out.
https://www.sau.com.au/forums/topic/438813-ignition-led/#findComment-7192865
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
