Hey guys, got my car back from the mechanic yesterday, after a full engine rebuild. I've since noticed that it has been boost spiking like a whore and im not liking it at all. It is set to 12 psi on the boost controller, just to run the engine in, didn't want to set it to its usual psi level. I am seeing spikes over 20 psi. Is my boost controller f**ked or maybe my external waste gate?
https://www.sau.com.au/forums/topic/438818-boost-spike/
Found the problem... inspected and hose from boost controller to wastegate was split, got a new one and fixed it up and she runs sweet now! The only problem is, my stupid self didnt think to look for 2 days now, the car was boosted a couple times before I realised that it feels like wayyyy too much for 15 psi. Could those couple of likely of caused an internal damage? the car seams to be running smooth as, just a little paranoid.. have further turned it down to 10 psi and keeping it low until I get the power tune done after a couple thousand k's
https://www.sau.com.au/forums/topic/438818-boost-spike/#findComment-7193410
Hahaha oh man.. that is crazy! Yeah car seems to be idling all good, runs well on 10psi now. Im just paranoid from when it was in the mechanic last, just really hope it didn't do any damage internal wise. Was only a couple and was hardly boosted, but when it was it was hitting very high psi until I noticed :(
https://www.sau.com.au/forums/topic/438818-boost-spike/#findComment-7193820
Yeah I know I cant change it haha. But since that's happened should I run a compression test or something just to make sure the internals etc are all good? or is that not needed. Car runs fine, idle is good. get a bit of backfire every now and then but I think that's just because I need a tune.
https://www.sau.com.au/forums/topic/438818-boost-spike/#findComment-7193828
Nah comp test isn't require unless something seems wrong. I'm sure it's fine I had this problem when I overboosted three times due to new boost controller setup wrong but all sweet two years later I did comp test at 172-168 across all cyl's
https://www.sau.com.au/forums/topic/438818-boost-spike/#findComment-7193850
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
