Hey guys, chucking together another engine, trying out with a NA RB20 on jungle juice e85, was running a TD06 20g on the last 20(DET), made around 300rwkw, super happy with the response, lag was never an issue, have another car i use for small tracks which has response, this engine will be more for open tracks, wanna see what i can stretch the little 20 to, more of an experiment more than anything. Have a HKS twin scroll mani i'm using, and still have the TD06 although it may be in need of some love (it's had a good innings), also have a precision 6265. precision is a bit of a jump, but considering it's there and wont cost me anything, i'd be willing to try it, i've definitely had laggier setups, then change if it proves too much of an issue.
The td06 25g is an obvious option, but i'd like to see if i could utilise the twin scroll manifold, ideally a ball bearing turbo, and with the high compression, squeeze around 330rwkw with around the same lag as the td06 20g, at less boost (26psi, had control issues). the limiter is going up to 8000rpm and possibly up to 4.6's from 4.1's. any ideas on a good turbo in that range, BB twin scroll, or is it not worth it?
while i'm at it, looking into a forwards facing plenum setup, possibly adapting the RB26 itb setup, but unsure if it will help with midrange, or hinder. For me, the benefits of simplicity and clearance with them are extremely beneficial out on the track, so i'd like to justify one performance wise as well. any thoughts on that one too?
cheers
https://www.sau.com.au/forums/topic/438851-rb20det-300kw-range/
6265 is way too big...they are a bit laggy on 2.5s but will make 400+
T67-25g would be my pick if you aren't fussed on having to rev it to the moon and back
Sooooooo....buy some good valve springs and rev that mofo!!!
i ran the precision on a 25 with a cheap chinese intake manifold and cheap NZ s/p ex mani (junk, but bought car as is), and it was pretty laggy but worked, only issue was when i went up to competition tyres, the clutch was too doey to keep the rpm up for it's setup. but it is a v-band housing-manifold, and it was running a cheap v-band so was leaking like a sieve. the 32 runs a much bitier clutch, hopefully decent plenum, the hks mani with no leaks, higher rpm (and higher ratio to suit), so i'd imagine it would be on par if not maybe a bit better even without the extra 500cc capacity. after currently running the same td06 turbo on both RB25 and RB20, i can say with all confidence that i much prefer the RB20's setup, however it did run e85 and more boost, but it was much stronger through the power region which counted for me (top end). The RB25 i run now with TD06 20g is better on the low speed stuff, but the 20 was still managable on the low speed, but had way more to give on the higher speed stuff.
rb20de+T will work well for response... drop in det cam shafts as they are different... adjst cam gear advance intake and retard zorst will net you more response.
intake mani- the ones that bolts on top of the factory one are bent to be better due to longer runners, although the ones like greedy one piece will hinder power/response due to shorter runners
hypergear aint doing too bad, check out the ss range
only going to 8000rpm so standard springs should be sweet, i assume they are the same de and det even though there are slight lift differentials?
as far as intake, i'd love the ITB's, really like throttle response, if it's too much work i won't bother, but it'd be ideal if i could utilise it. Just not sure how, looked into cutting and shutting, but where? possibly cutting off the runners right at the flange, running some tubing with a laser cut flange to suit rb20? could be a chance to add some length to runners if they are a little short standard. not sure how that will play with fuel delivery but will be run with motec m500 which should allow some control.
think its slight lift and duration difference which might cause power band issues, seeing that your after as much power as you can get out of it . should just rack them out of the broken det
Not any real input, just a question. Wouldn't running ~26psi on a DE+T kill it very very quickly? I know running ethanol will help but surely running high comp and high boost would lead to extremely high cylinder pressures that the NA rods just can't cope with? Don't really know too much about all this stuff, hence the question. Genuinely curious.
going to give it a whirl, plenty examples around with 30de and 25de's, i'm not planning on running 26psi, that was my old setup on the DET, it actually ran aroud 30psi most of the time due to control issues. never bothered to fix it as it never had any problem running it all day every day haha.
plan is to run 17-20psi (maybe higher if the turbo i use needs it), the E85 is pretty amazing stuff. afaik RB20DE rods are the same as RB20DET rods? or at least strength wise. haven't pulled one apart yet to confirm, if they are weaker that'd be very usefull info. main worry atm is lack of oil squirters, but looking at RB30's i'm thinking it's not the end of the world.
na rods and DET rods are the same, in fact the whole bottom end construction is the same, just the CR changes. also boost pressure doesnt kill engines (to a point) rather its excess or uncontrolled cyln pressures that does. if you can get the tune right and control the combustion you'll have a happy engine that runs right!
thankfully Nisskid and myself have a tuner who is more then switched on enough to do the job. case in point is my own car that just keeps going and making 400+ rwkw on stock rb30e bottom end
Wouldn't running more boost increase cylinder pressure? Or is the difference between 10 (standard) and 26 psi hardly worth noting when cylinder pressure is so high anyway?
9:1 compression ratio means that whatever you put in there to start with gets squeezed up to 9 times the original pressure. If you start with no boost at all, then you end up with about 9 times atmospheric pressure. If you run 10 psi boost on top of atmospheric, then you have (14.7 + 10)/14.7 to start with and then you squeeze that 9 times. So now instead of maybe 132 psi, you have maybe 222 psi. And if you were to start with 26 psi of boost, the ratio now gives you 366 psi.
So, yeah, 26 psi does make a hell of a difference to cylinder pressures compared to 10 psi. That's the whole point.
** Note that I've only done simple ratios up there and haven't taken into consideration any aspects of head flow efficiency or non-adiabatic compression effects etc etc. It's just for illustration.
http://www.tomei-p.co.jp/_2003web-catalogue/e090_camshaft-specs.html
this is what im going off.
still struggling with turbo choice, thinking about grabbing a new rear housing, maybe a touch smaller and twin scroll (assuming that's possible, feel a bit rookie asking, but i assume twin and single scroll internals are the same besides the housing, blade design isn't different?) for the precision, here are my choices
https://www.treadstoneperformance.com/product.phtml?p=2169&cat_key=596&prodname=Precision+T4+V-band+Turbine+Housings%2C+Twin+Scroll
.82
1.00
1.15
1.32
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
