Hi all
On a trip moving from qld to vic i drove the gtr. Checked over it all and had not long replaced all the fluids inc. diffs, gearbox, brake/clutch. When arriving in vic i noticed a faint whine in the rear. Dropped the rear diff oil to make sure all was ok and replaced with new. I never drive it far and since being here the noise has become louder in the rear right between about 70(loudest) and above(slightly quietens). When driving if i flick turn to the left i gets louder and to the right nearly dissapears when the weight is off the wheel. Another thing of note that could prematurely wear them is it has 25mm wheel spacers to bring the inset wheels back to normal but they still sit inside the guards
@ 130,000 is it likely that a, $350 to replace wheel bearing\hub as they are, is on its way out?
Is there any alternative? I understand there is a repco $80 bearing that has to be pressed into the hub after the origional is pressed out however i have been warned away from this as it may never be perfectly alligned like the nissan part
Has anyone had similar problems to myself
Thanks
ps i live in Geelong and may need a good mechanic to do a vic rwc if anyone knows of someone
https://www.sau.com.au/forums/topic/438863-32-gtr-wheel-bearing-issue/
I went through this a while ago, 32 GTR's use a unique rear wheel bearing assembly, other model bearings were diffrent on the mounting face, i ended up getting a genuine Nissan bearing for the GTR and the noise went away, mine was also the drivers side.
I recently had both my rear bearings replaced, wasn't so much a noise problem but one of my wheels had abit of vertical play, decided to get both done. I went with the OEM Nissan ones, after hearing that going for the cheaper option could end up being a headache, i ended up getting new hubs also (apparently that was a good move as the one that had play in it was damaged and needed replacement) ended up being quite expensive though around $250 each for the bearings and another $230 each for the hubs!
Edited by Gza36
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
