I just asked the question. coz my car had a label of unleaded. not sure what rating it was.
Plus i have read somewhere that E85 mixture is ok for the car too.
But i do agree with people here. i get more mileage on my cars when its on 98ron. runs better goes longer.
According to the FSM, the ECU switches to a 'knock map' when it detects knocking. But I have never observed it or tried to trigger it.
Yes, but there seems to be this perception that the ECU "removes" timing when it detects knock on the fly.
I've never seen any evidence of it, when I played around with Uprev and set the knock map up, it is quite simply just another Ign timing table to set say 20 points lower than the standard table.
E85 requires a custom dyno tune, complete with a marginally larger set of injectors.
As above, you CANNOT dump a tank in and expect the car to run ok.
  • Like 1
Yeah good luck with all that.
Its amazing what other kids can tell you in the sand pit these days
Edited by Howaitonaito
sometimes its just good to know...hehe Thanks for the info guys!!!
fyi: my 350GT has never tasted petrol below 98ron in my care.
Yes, i believe that is correct, it is just a 2nd map with a fairly heavy timing retard (and fuel mix richen).
The FSM specifically says the knock sensor is a 'last resort safety device' and is not a tuning device, so when knock occurs the ECU just smashes back the timing to try to prevent damage, it was not intended to 'adjust' to low octane fuels.
And the other false perception is the ECU uses the knock sensor to advance the timing for higher octane fuels.
the only ECU I know that actually uses multiple knock sensors to 'tune' the timing is the newer WRX STI ECU.
Well the article i read was from cars guide and not specifically talking bout our skylines but were talking about modern cars. Im guess anything over year 2000 is a modern car.
That is why there are forums like this to ask questions and get answers from experienced owners.
Thanks for your statement though.
If that place you read that awesome piece of factual *cough* information also said the the boogie man exists would you believe them.
No.
Has anyone used e10 91 on their v35s?
Our cars can use 91ron but not sure if with E10 would work.
read me
http://www.unitedpetroleum.com.au/united/fuel/unleaded-e10
do a little homework ,...e10 is 95 octane...i dont know why the misconception I hear so often, I guess because its cheap eveyone thinks its low octane...Its 95 octane at cheaper cost....and yes it should be fine to run...run it in my 04 honda all the time...may get 50kms less a tank but at least i know my injectors are clean...
No way is e85 ok for your car.
some cars with high compression rates can run it ok., I know guys in USA have tested it in Hondas and it runs good and pulls harder faster than petrol.....
that said
Its still not a very good idea but if it were an emergency you can get away with it
You would be surprised how much e85 you can put in the tank before the ecu calls it quits and throws a code. Remember the o2 sensors in these modern cars are very good at re-calculating short term fuel trims. I have heard 50% is usually ok.
But they run to AFR... Not lambda.
E85 and 98 have different stoich ratios. Which the O2 sensor can't take into account. It's fixed on 14.7- petrol.
Both have a lambda of 1 ( lambda is just the indication of the best or most efficient ratio). So you might then tune petrol to 11.5afr, however that isn't equal to the same ratio when using e85
As the sensor reads lambda it automatically compensates for different fuels. I tune e85 to 14.7:1 on my gauge and it is just as stoich as a petrol tune. (just remember, e85 isn't 100% ethanol anyway.)
United 100 octane is garbage. its not really 100octane since it uses 10% e10 to boost the octane rating. been using it until i got my car uprev tuned and now running shell 98, much better
you are a moron. octane is octane. it's a way of measuring any fuel. LPG has an octane rating too. E85 is ~105-110 octane depending on the exact blend.
United's E100 works really well. In my R33 it was noticeably better than 98RON.
Yeh, it's 100 octane ;) lol
I get poor economy using it compared to normal 98ron fuel.
Up to 50% worse km per litre (ie 250kms for 60L of United 100 compared to ~370kms with Mobil 98)
50% worse? It's either your right foot or something is seriously out of whack with your car. I ran United E100 all the time and it made almost no difference to my fuel usage.
O2 sensors work by sensing lambda, not AFR. They measure the ratio of oxygen in the exhaust gas to oxygen in the air, and their output changes around lambda 1 regardless of fuel. The O2 sensor doesn't know you've squirted 14.7:1 worth of fuel into the motor, it doesn't care. All it cares about is how much oxygen is left in the exhaust gases and that is lambda.
  • Like 1
Ok, so let me try to understand this.
Hypothetically, you can fill up your stock as a rock car with e85, drive it around on closed loop, and have a e85 lambda of 1?
What is the e85 afr equilivent of 14.7?
No, because the stock ecu will only add or subtract around 10% of the fuel. Anything outside that range will trigger the MIL as the ecu will know something is seriously wrong.
Ethanol stoich is 9:1 I think. Not sure what e85 would be as I have never needed to know.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
