9.8:1 says google for e85.
Vq35 stock ecu and add/ subtract 25% fuel, sadly I know from experience.
So, if it had an infinite range, on e85 it would still be able to trim fuel to lambda, the sensor would output volts that the ecu sees as 14.7, and the real afr would be 9.8:1?
octane is octane. it's a way of measuring any fuel. LPG has an octane rating too.
Indeed!! Many people think octane or RON is some sort of fuel quality figure or fuel energy density figure.
It is not, it is just an indication of the fuel's resistance to detonation.
Both LPG and E85, have octane ratings above 100, but they return reduced fuel economy.
Edited by sonicii
If the ECU were able to adjust, would the stock injectors be able to keep up with 33% increse in fuel demand?
I've tested BP98 Vpower Caltex98 and United P100...from my experience, BP98 works best with better fuel economy than Vpower and Caltex.
BP98 vs P100...not really noticeable but I "feel" that P100 gives me more pull. Economy wise...slightly more with P100 but could just be road conditions..Nowadays I only use BP98 or P100 depending which days I need to get petrol as P100 is usually cheaper.
Did you reset the ecu to clear the long term fuel trims though Colin? Not a good indication if you are just changing for one tank full, plus the fuels would be mixed as the tank wasn't empty.
I would expect less K's to a tank with any e10, there is slightly less energy density.
Hey Scott, I do at least 3-4 full tanks and average it out, and then reset ecu for the new fuel and repeat.
Both my V36 and R34 does better with BP98 as well over the Caltex and VPower...
P100, pulls better and does similar K's to BP98 or just a bit more.
Actually thinking about it, P100 pulls better over Caltex and VPower....comparing to BP maybe same or so...that one I am not too sure considering I use either one.
Recently though I got my V36 tuned with P100 in it...
Do you think mixing BP98 and P100 would be a problem?
Edited by colin.ssc
No, any car can run on ethanol if you have enough overhead on the injectors, or just stick 30% larger injectors in and let the stock ecu work it out. :)
this advice really should come with a disclaimer...*results may vary*
Agreed, if people didn't realise, injector overhead requires you have some form of injector control, eg Osirus cable for the V35.
As I learned in the MoTeC training seminar back in 2004, they use lambda in their ECU software because it's a universal representation of the stoichiometry as opposed to having to remember all the different AFRs for different fuels.
Therefore, a lambda of 1 in an ECU map will translate to the respective stoichiometric AFR for whatever fuel you are using.
That said, not all wideband O2 sensors back then were fit for all fuels, so there were different sensors to suit different fuels. Changing the fuel type meant changing the sensor too.
I'm not sure if that is still the case today.
As far as I can see in the UpRev Osiris software, of what little I've looked at so far, they map in AFR terms.
[Edit: Actually, I think there is a choice for AFR or lambda in the software's preferences for units of measurement. Just looked it up but couldn't confirm since I'm overseas without my Osiris cable!]
Edited by The Max
95-98 ..is there really that much difference? if i can get 95 octane e10 for 1.30$ a litre when 98 is a 1.60 a litre...thats at least a 15$ saving on a full tank of fuel...if i am using a tank a week thats maybe an 800$ a year saving...thats my registration paid....add to that ethanol will help clean your fuel system as well as any additives they put in 98....I don't see the problem except maybe 2kws and a bit less range..and i dont use 15$ worth of fuel in 50kms...
if e10 was the only fuel at the pump, everyone would run it ..but people like choices, this is the MAIN reason we have different fuels...if water was the only drink in the fridge, you would happily drink it but no, go to a servo and there is 4572 different drinks to choose from...why? because peopel like choice...truth is it really makes no difference what pump fuel you run because your car was built for its tolerances in mind......true some fuel might make your car live a little longer, but alot of people couldn't care care less...cars are disposable...
The way I see it, Ithought these vehicles were made ideally for 98RON. Why skimp on the fuel in the first place?
people like choice
end :rant:
95-98 ..is there really that much difference? if i can get 95 octane e10 for 1.30$ a litre when 98 is a 1.60 a litre...thats at least a 15$ saving on a full tank of fuel...add to that ethanol will help clean your fuel system as well as any additives they put in 98....I don't see the problem except maybe 2kws and a bit less range..and i dont use 15$ worth of fuel in 50kms...
if e10 was the only fuel at the pump, everyone would run it ..but people like choices, this is the MAIN reason we have different fuels...if water was the only drink in the fridge, you would happily drink it but no, go to a servo and there is 4572 different drinks to choose from...why? because peopel like choice...truth is it really makes no difference what pump fuel you run because your car was built for its tolerances in mind......just like it doesnt matter what drink you choose from the fridge its going to kill you anyway..
people like choice
Water is better for me than any other beverage. It's not really a fair comparison. Using 95RON as opposed to 98RON isn't recommended for the vehicle and it has nothing to do with choice. I can also choose to scratch my crotch with a cheese grater, or perhaps less severely, wash my car with a scouring pad but that doesn't make any of it a wise choice. You put in what it needs, not what you choose.
A Toyota Yaris is made for 91RON so with the possible exception of slightly better fuel economy (though I wouldn't know for a fact), there'd be no benefit for 98RON.
A V36, on the other hand, is made for 98RON so running 91RON would simply be deemed inappropriate.
The choice we're given is what car we choose to drive and in turn what support we get at the bowser. There's not much choice with the fuel, from my point of view.
Edited by The Max
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
