Redline Escort Radar Detector Pro A (New)
Units like this need to mounted on the windscreen - not a big deal these days with every other vehicle having mobile phone and/or GPS units mounted there aswell. There are more advanced ones that use sensors on the dash/back window/front grill, but the unit hides away.
You can modify a radar detector to become a detector-detector - this is what the police use and it provides a signal direction too. Most decent units have a shut-off that once it acknowledges that it is being tracked, it will stop detecting to avoid being identified. This obviously only works if there are other cars around. If you're by yourself, it won't matter.
It will pick up mobile radar no problem as they tend to operate continuously and as someone said, the signals bounce off anything/everything. Speed cameras are a strange one - some operate continuously (easy detection), some operate sporadically so you might think its a false signal and ignore the alarm (shopfront motion sensors for automatic sliding doors can set some models off). Lasers are difficult - they hardly reflect off other vehicles, and if it gets pointed at you, you'll be warned as your speed is recorded.
This is all just general knowledge to answer some questions, not specific to the model being sold here.
  • 3 weeks later...
After all of this talk ,are these things any good?
Or, if caught you are in more trouble than just the speeding ticket????
Is there a product out there that gives us a fighting chance if we slip over the limit, without being fined for having a radar detector in our car.
If they have to put up signs saying there is a radar speed detector up ahead , why are we not allowed to have something to detect them ??????
Before you shoot me down, "do not speed" and then "no problem" shit it is hard to stay within a 5k limit with a modern car where 1 or 2MM on the peddle is about 5 kph :w00t:
I have done lots of dumb driving over my life in cars that should not have been on the road and today would be scrapped , F, cable brakes were fun :w00t: the car could go twice as fast than it could stop :stupid:
I do 3500kms per week, I use one and cannot recommend them highly enough, yes they will go off at certain business/servos. yes the police with a handheld need to be locked onto your car for it 2 pickup laser alert, yes it will pickup highway patrol cars with there radar turned on before u see them and yes it will pickup flash for cashes parked on side of road. good luck with sale, good price :)
i just got a speeding fine, he said his laser showed i was speeding, so my question is does this unit tell me if a cop has a radar with a laser before i get in range of it?
Uhh, no.. by definition if you're not "in range" then how is the detector supposed to detect the radar or laser signal? a signal has to actually been seen by the device to be detected. with the laser speed measuring devices cops use today, you will have only ~1 to 2 seconds to drop your speed if you're speeding before they lock in the detected speed, in other words not enough time. Another approach would be to attempt to "jam" the signal by diffusing the laser with noise on the same wavelength buying you another 4-5 seconds to slow down... but not all of these have success in actually working as advertised, and are also illegal. Also note that most detectors are easily detected by police scanners because they emit a signal which can be identified - the only one i know of that claims is not detectable is the Bell XR/STi.
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
