Have decided that i want to buy a house in the next year so rather than this sitting there collecting dust i would prefer the money.
Engine has done about 5000kms since rebuild and most of the other stuff has done 2000kms if that. Done up a quick list, prices i'm fairly firm on atm.
*Need to organise somewhere to strip the car before i start as my garage won't work.
Sr20det long motor (standard rebuild with receipts/gkteck stoppers/de cams) -1600
Gearbox with everything for manual conversion - 1000
Kakimoto Cat Back exhaust (tucked/cleaned by Nathan @ Fabulous) - 350
IHI rx6 turbo (tcw15 p18)/HPC coated Powertune manifold/lines/HKS gate/dump/intake/intercooler pipe - 3200
Haltech e8 with boost solenoid, plug in – 900 why buy a power fc
Sard fpr
 with fitting/lines - 90
Billet fuel rail and Rochester 860cc injectors – 400
Sard/denso 850cc injectors with standard rail – 300
HKS cam gears - 250
Greddy copy inlet manifold
 -150
Hyrbid Front mount core
 - 200
Greddy oil cooler and relo kit
 - 400
BA Fans
/Saber rad
 - 250
ARC sump
 - 250
Greddy sump – 250
GKtech Bash Plate
 - 50
Carbing strut brace w/ BMS
 - 150
BC Racing coilovers 8/6– 800
SPL PRO outer tie rod/Tein z33 inner tie rod -250
SPL PRO tension rods v3
- 200
SPL Braided teflon clutch line
- 40
SPL PRO rear toe arm set v3
- 200
SPL PRO rear upper arm set v3
- 280
SPL PRO rear traction arm set v3
- 175
Whiteline Sway bar
 F and R (adjustable) – 400
S14 LCA's/s14 knuckle/hub/R34 Front caliper/R34 slotted rotors/QFM Pads/SPL Lines - 700
R32 GTR caliper/QFM Pads
/Project Mu handbrake shoes
/Slotted rear rotors/SPL Lines
 $450
R32 GTR diff/ Spl solid diff mounts/ half shafts/ knuckles - 700
Non hicas rear cradle - foam filled with SPL solid bushes - 250
Cusco rear strut brace -100
Cusco safety 21 5 point half cage
 - 400
Recaro Spa carbon kevlar drivers seat and rail - 700
Recaro Top gun seat (perfect) with either passenger or drivers rail - 700
Personal steering wheel - 150
HKS DB Chrono gauges - Boost, Water Temp, Oil Temp, Oil Pressure
brand new temp sensor and oil pressure sensor - 500
Genuine type x front bar with lip/side canards/lights and indicators – 650 (will not separate lip from bar,unless someone only wants bar)
Type x rear lights with carbon center
 - 550
Genuine Bomex skirts
 -130
Genuine Gp-sports rear bar -100
Carbon Ganadors - 250
Raybrig headlights with motor etc – 350
326 Power Roof lip – 150
326 Power boot lip – 150
Koguchi Bonnet - 1000
Non rolling shell – offers, will be without whats listed above
5B989239-1AA2-46F8-B60B-A4B4D6DB0101_zpsIMG_0281_zps927b3b61.jpgB34AE596-A40B-4C90-9F9D-B85F3F6F0C96-45836D8B8F5-2EC3-48A4-B29B-C186DBA0CAEE-347E406DE93-E38B-46E4-BDAC-8E02F43BE31E-194F3EDF538-410E-47ED-AB0C-D7BCD9DD8CD9-194
https://www.sau.com.au/forums/topic/438919-180sx-part-out-quality-parts-galore/
  • 2 months later...
  • 1 month later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
