Hi guys, bought a set of Panasport G7 C5C's off Yahoo Japan through Import Monster.
Managed to be a decent price, with the only caveat being no one could tell me how wide the rims are. They're off a 32 GTR so I'm not worried about off set or them being staggered, but I'm trying to source some tyres while I wait til they arrive, and I can't buy tyres until I know what size they are. Hence the thread.
Form the photos below, can anyone here reliably guess what size they are? They have 245/40/18 tyres so they must be at least 9" right? Any chance they are 10'? Anyway check them out and let me know what you think.
Could be the angle of the photo, but it looks like there is small tyre stretch, so they COULD be 10".
Unless someone has the exact wheels or you're able to track down the specs online, might have to wait for them to land before hitting it up with the tape measure.
What specs would I be looking for? I'm pretty sure they came out in at least 9's & 10's. Would you bother stretching a 245 on a 10'?
Would it be risky buying a set of 295's?
Honestly, I'm not sure what tyre profile GTRs run so hopefully someone else with a GTR can help you on that front.
Just from the pics, they do look like a small stretch and at the end of the day, it's possible someone might have gone undersized for whatever reason.
Personally, I'd wait till they land. Nothing worse than buying tyres that aren't gonna work and then shelling out more cash for tyres that will. Besides, they're not gonna be a hard-to-get tyre so should be able to drive down to the local tyre joint and get them sorted.
Should've mentioned I'm looking for second hand semis, which are a little bit harder to come by.
You're right though I don't want to shoot myself in the foot and buy tyres I can't use.
If i was to guess id say they are 9 inch rims as a 245 tyre would have more stretch on a 10 inch rim than what it appears to have.
I agree with this. Maybe even 8.5 imo.
245's on 9in vskf's on wifey's zed look to have more stretch than these do.
Definitely 9" at minimum. Possible they could be 9.5"? The angle of the tyre's sidewall is close to how a 235/45R17 S-Drive fits on my 9" rims. They don't look to be 10" wide though.
EDIT: Using a tyres width to judge wheel width is pretty useless as they can vary up to about 10mm in width across manufacturers...
Edited by colourclassic
Im running 9.5" TE37s with 255 Nitto semis right now, and have used 255 Toyo semis in the past and they seem to be a great fit.
Pretty flush side wall. So a 265 should be all good.
Nt01's? what did you think of them?
I havent had a chance to really give them a good run. Need to sort out a few little issues before i give it a day on the track. Then Ill really see how they perform.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
