Hey guys, I've been tossing up whether to sell my 32 for the last couple of months. I think the time has come to let it go. I plan on traveling overseas in a few months and with a gtr sitting in my driveway begging to be modded it's not going to happen. I'm open to swaps for lesser value cars plus cash my way. Now about the
Car
I'll start with the bad-
3rd gear synchro is rough at high rpm, daily driving, it's fine, just at those higher rpm changes.
There is also a Scratch on passenger door which will be fixed before sale if price is right.
The car is a 1989 r32 gtr
-Nistune, tuned at Nextup performance currently running 210awkw on a very safe tune (factory boost)
- beautiful millenium jade respray car is immaculate (except for the passenger door)
- 320km/h mines cluster
-Pillar mounted boost and oil pressure gauges
-stock, great condition interior.
-AWD-RWD switch mounted in Center console
-exhaust from front pipes back, decat.
-old school apexi multichecker, can throw in an avc-r depending on sale price
-Front and rear strut braces
-Walbro 255lph fuel pump
-Genuine ROH modenas with good tyres
-HKS pod filters with custom air box
-Engineered FMIC
-Sard 650cc injectors brand new
-Nismo adjustable fuel reg
-oil cooler and catch can (not currently connected)
-oil filter relocation
-New clutch master cylinder
-New button clutch
-Tein coilovers
No dash bubbles and the interior is in good condition, typical wear on drivers seat.
I'm chasing $14,000 with 6 months rego, or if you want to supply your own wheels to make it cheaper I'll take $13,200. Sad to see it go, but being at uni and travel plans I don't have the time or money to enjoy it as I'd like to. Located Brisbane. Can send more pics via text, 0435435602
https://www.sau.com.au/forums/topic/438927-32-gtr/
Wouldn't have a clue sorry mate. I would of been after a second hand box in good condition as you can pick them up quite cheap now. At a rough guess I'd say anywhere between 1-1.5k for a rebuild and fixing the synchro. Yeh bonnet is open in those pics. Guards and bonnet line up perfect
https://www.sau.com.au/forums/topic/438927-32-gtr/#findComment-7195174
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
