No stereo really, a CD player and 2 front speaker, no amp lol. Eboost runs off it and standard accessories, that's about it. A mate works in spare parts and has priced up all the cables, battery clamps and isolator switch etc. I don't drive the car very often either. Maybe try to start it fortnightly for a bit and go for a short drive but that's about it, track days are pretty few and far between really. In the HR31, there are pits on either side of the boot, one to hold the space saver and the other side for tools and jack so if the battery fits, it may go in there. I don't intend on smashing it so should be safe enough there? It would restrict any movement should the bracket fail for whatever reason.
The under car would be quicker but if you hit something or catch it underneath very dangerous. Its a little bit more pain to put the cable through the car but will look a hell of a lot neater, almost factory. And be a hell of a lot safer then having it dangling under the car. For an extra 30min or so of mucking around its well work the effort. To make it quicker you could always take out all your seats ba the drivers one before you come here. Then we can pull the carpet back that way and will be a lot quicker and easier :)
I was thinking of at least pulling the rear seat out before I bring it. I know that's the easy bit. When I have all the gear together I will send you a PM and work out a time and date. I have got a fair bit on in March, going away for F1 weekend and also a weekend away for an engagement party, working a weekend in between etc but we will be able to work something out somewhere along the line. I'm all for neat work btw lol.
If you're only running standard cd player and accessories then 0 gauge might be a bit overkill as Johnny said. I reckon you can easily get away with 4 gauge and will reduce the cost of cabling a bit more.
Luke - were you planning on running the positive directly to the alternator?
On my 32 i ran the positive to the starter and alternator plus the fuse box. Ill have to see where the factory wiring goes from the battery, essentially the easiest way is to take the feeds from the original +v terminal directly to back of starter or alternator. Alternatively you could put a kill switch in the engine bay or "iso" with 1 side comming from the boot and the other from the original +v cables running from fuse/starter and alternator.
  • 1 month later...
Update, taken all of your advice in to consideration. I have the positive and negative cable, battery clamps, other u-clamps, kill switch and just ordered the Optima D34 :).
Battery isn't expected to be here until March 31st so not sure if it will all be done before the track day on April 23. Once this is done I can book the car in with Jez for the plenum install and retune. Happy times.
Luke, I will PM you once the battery is here and work out a day to get this done! I do like how you did it in your 32. Where did you get the black cable protector from?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
