Would not try. All the engine torque will go through the gearbox mounts. The engine will flail around in the bay unless you have the magic touch on the throttle and clutch. You don't want to stretch and stress the various wiring looms, hoses and other connections on the engine.
It _could_ be done, but definitely not advisable.
I think he's taking about the bolts holding the gearbox to the engine, not the mounts.
Cant think why you would want to do that, but I would say a car will work with heaps less bolts than it left the factory with, what that number and what bolts I dont know.
A loooooong time ago one of my boys bought a 20det engine/box from Adelaide Jap Motorsport who were THE import engine people back then.
We dropped it into a VB Commo and she went for ages with NO engine to box reinforcement pieces.
That's the way she turned up, wired onto a pallet.
Engineer had also never seen a 32 so he didn't notice anything amiss.
Eventually a mate who had actually seen an R32 pointed out the missing components so we got in touch with Adelaide and they posted them up.
No idea why the engine was delivered missing the bits but at a guess, they'd done a box swap and got a bit lazy.
Obviously it didn't break in half or tear itself to bits but it sure looked a lot stronger with those reinforcements attached.
Any up down or left right movement between the gearbox and engine may result in a bent transmission input shaft.
Ive seen a few cars with up to 2 bolts missing being driven, however the others were tight, not exactly the best thing to be doing driving it that way.....
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
