hi guys i want to fo FI for my v35 coupe.
Just wanted to see if anyone is selling or thinking of selling thiers?
I tried the hks supercharger kit but looks like theyve discountinued it?
Or if you could advise where i could find decent priced ones at
Thanks.
https://www.sau.com.au/forums/topic/438957-wtb-turbosupercharger-kit-for-v35/
Looking to sell my GTX3076 kit very soon, I am dropping back to the GTX3071 as the auto doesn't like the torque I am putting to all 4.
Don't bother with centrifugal supercharger kits, they have the lag of a turbo with the added supercharger power losses to spin it up.
Hi Scotty,
Dont much about these, what brand are they and anything i will need in addition to fit in the v35? will it be a straight bolt on kit or? and how much am i looking at $$?
so the hks supercharger are centrifugal? only reason i wanted to go with a blower is because it was bolt on and no fabrication needed.
Thanks,
Is the HKS supercharger kit bolt on for V35 or only 350z? I know there would be mods required for a Stagea nose.
I can sell you my whole kit, but you will need some cooler and piping fabrication. I can include the front half of the exhaust, manifolds intake, external gate etc so you would be well on your way. Where are you located? I can do most of the fab work if you are in Vic.
The Stagea is a V35 from the drivers seat forward and the manifolds bolt up, a few studs will need to be moved to different holes though. There is a far bit of work fitting the crossover pipe, might be easier to drop the engine to fit it all.
I can also make you up a new kit if you want to drop the car off. ;)
PM me if you want to discuss pricing for various options. Do you have a power figure in mind?
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
