Been looking at a car for ages, Its common sense every young guy wants the greatest car, as his first car, But its a learning car, So meh i dont mind, (im still after something decent)
I would buy a r34, for one its my first car i dont want to ride off a good car (if i do) there mostly turbo, cant drive etc.
What would you get as your first car, Only decent cars i like a s15/14's, R34 * R33, Supra, Wrx, Thats about it, Like there all not cheap cars, Arghh its annoying. Any advice?
https://www.sau.com.au/forums/topic/438986-what-would-you-get-as-a-first-car/
you should consider insurance when deciding as well all those above, including that ferrari will charge you out the arse for insurance....
if i had to get a first car around now... I always like the early 2000 liberties, good for highway driving, leather seats ect... mum had an auto one, id prob try and find a manual if possible, any auto car shits me to tears unless on the highway
Yeah gotcha, thanks for the reply, i acutally was forgetting about insurance and thats something i HAVE to keep in mind, yeah i dont mind liberties might have a look around thanks !
small-house-with-nice-car_zps2780f2cc.jp
Get an old grandpa car, like a crown or something, more possibility it hasnt been thrashed like an r31, you want something that has had an easy life and is ready for you to abuse it with everything breaking that way you can save and buy something nicer when your ready, plus your friends wont want you to be designated driver if its ugly as.. Hahaha
Hahahahaha ! so true, yeah very good points, thanks man. hahaah
my first car was a 92 civic with a F'd clutch.. was great for fuel.. insurance was cheap as chips and having a shotty clutch i could drive alot of aftermarket clutches after moving on because it was almost an on off switch haha. it was battered and beat but ran 350,xxxkm with out a fault
get like a mazda 626 or primera or anything for under 5k thats had a grandpa life they mostly decent on fuel no atention from police. and insurance is not ridicules.
like mentioned save until your on your fulls to buy a nice turbo car in good condition, you dont want to skimp out an buy a cheap dud turbo car on its way out, and you will have most of the work cut out for you since you wont have to do a full turbo conversion and having it off the road for a lengthy period of time.. plus you will end up having much more money, respect and experience for it when the time comes
you may hate driving a nana car for a few years most people do, but think of it this way. in that few years time how much money can you have saved to say buy your future r34 and treat it to some nice new treats?
had a friend who went and bought an NA s14 on his restricted license (P plate equivalent) and regretted it because it wasnt "as quick" as other non turbo cars these days sold it for 3k less then he bought it for, before buying something half decent when he got his full license. cant say he was to impressed
just my 2 cents :) good luck mate
Cressdia for for the win....:D
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
