Thanks for all the replies !!
I think i might just get a cheap car first then, work on a better car down the track, Im looking at a nissan pulsar for $500 mate owns it seems like a perfect car to learn in, Opinions? Its a manual, going to get more information soon.
Swift GTI. Too bad they're flimsy and most have been trashed or worn out. Lots of fun for very little cash otherwise.
Hard to recommend the R31 I had one for a couple of years and found that all the Australian made bits on them are awful, the diff especially. The whine will send you deaf on the freeway. Other crappy bits are the seats (frames break), door trims (peel apart) and the steering racks (love to leak fluid). They are easy to fix though and the engines will go forever...
R31 Skyline/Pintara wagon.
Cheap, reliable and you can r00t in the back...or so I've been told...
You can also carry half your wardrobe and a heap of other shit you need when you inevitably end up living out of it days on end when you're out getting pissed with your mates.
  • Like 1
Manual is a win. autos are pretty terrible. anymore details on the car?
do a comp test, the 1.6 and 1.8L motors in the N16 like to blow head gaskets
wont get N16 for $500, and I'd say to steer clear anyway. too many differences between models. ie. hatch is a totally different car to sedan, S1 is a different ballpark to S2, very few interchangeable parts and the 1.6 and 1.8 are completely different engines.
Bit of a mess really.
Whatever your budget is go buy the best corolla you can afford. About an 05 model should do
Auto frees up a hand for eating drinking, fingering or pushing the horn
  • Like 2
Agree with most others, but I'll add to buy something you won't be tempted to modify in any way, like a Camry. Reliable, big enough to cart stuff around in, dull as ditchwater.You may grit your teeth every time you drive it and cop some flack from (idiot) mates but wgaf, you'll have freedom of mobility and can save money you would have wasted on pointless mods towards something decent. And as Alex said, you won't care so much when you gutter the wheels and round off the bumper corners.
I really think corollas and camry are overpriced because people think they are well taken care of and rarely driven. Old people or not, you cant confidently say that about any car on the market.
While I think the older corollas are ok (other than toyota retarded gear ratios), there are quite a few around with rolled-back kms.
My first car was a S3 R31 skyline.
Was an awsome car to learn in, cost me $3000 (10 years ago) less then $1000 to fully insure.
Started as auto but converted to manual.easy to modyfy and is p-plate friendly.
Is also RWD which personaly is better to learn in then a FWD.
You can pic one up these days for around $1000 with mods.
Pulsars are a win!!
My first car was an N15 SSS, I've had it for over 7 years now, have put it through it's paces, and has never failed me!! It's still running with 255k on the clock and has never missed a beat..
I wouldn't necessarily go for a standard pulsar though (with a 1.8L engine or less).. Seen too many with problems!! The little extra money for a SSS with the SR20 in it goes a long way!!
Cheap to fill - $60 for a full tank of Premium; cheap to maintain; and cheap on insurance!! PLUS it's a NISSAN, so it's bulletproof by default ;)
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
