Make: Nissan
Model: 350Z Track
Year: 2004
Body Style: (Coupe/Roadster/etc)
Colour: Pewter Grey
Version: (Track/Touring/Anniversary/etc)
Engine NA
Transmission: Manual
Interior Material/Colour: Sunburnt yellow
Odometer: 12*,***kms
Price: $24,500 negotiable
Contact Details: 0410888383
Comments:
Up for sale is my 2004 Nissan 350z Track Edition. The car has been great since the day I purchased it, I've never had any trouble with it, the car is serviced regularly by me, the oil gets dumped every 2500 to 3500 kilometres depending on how burnt the oil is. I have been told this is excessive but I don't like running with burnt oil.
Over the years of ownership I have upgraded some components for better performance as listed below:
CUSCO ZERO 3 - COIL-OVER SUSPENSION (20 way adjust-ability)
CUSCO - REAR CAMBER ARMS
CUSCO - FRONT A ARMS
CUSCO - FRONT AND REAR SWAY BARS
This set up alone cost $4000, I didn't want to lose comfort but be able to customise it easily to different drive types. Drives just like factory now with a bit more sharpness plus room to improve with its adjust-ability.
(complete OEM suspension + camber + a-arms + sway bars can be included)
TOMEI - EXPREME V2 HEADERS
STILLEN - HIGH FLOW CATS
X FORCE - EXHAUST SYSTEM
K&N - COLD AIR INTAKE, AND PLENUM SPACER
(complete OEM exhaust can be included by request)
These modifications have opened up the throttle response and given the car a exotic exhaust note without having any annoying back pressure sound while cruising. The only time there is any rasp in the exhaust note is in 2nd gear at WOT which in my opinion fits the car.
VOLK- GTS 19 INCH (9.5" front and 10.5" rears - brand new these cost $4600 plus shipping)
Currently running on about 80+% tread with federal tyres evo 595's, the grip on these tyres is awsome, (medium to soft tyre).
NISMO - TITANIUM SHIFT KNOB
I-POD CONNECTIVITY - integrated into the OEM stereo and also charges the ipod/i-phone
the standard stereo sounds great, good balance for the cabin setup.
(extra speakers included + oem head unit)
The clutch and flywheel have been replaced with a custom single plate heavy duty clutch, and a extreme single mass lightened flywheel late last year. There is some light chatter from the flywheel but isn't overly noticeable while driving but the clutch peddle is very light.
As a standard car it is solid on the road with very minimal road noise, with cruise control for freeway driving factory Brembo braking system, this car is the complete package with nothing to spend.
The Zed has been meticulously maintained and never missed a beat. Regretful sale but selling to cater for other commitments.
I highly doubt you will find a Z car like this one, there are some chips in the front bar and a small dent in the passenger door (whilst in carpark) but overall for a 10 year old car it is immaculate.
No low ballers please, anyone that has a real interest please call or text me with any questions, I'm am negotiable on the price to an extent and have a set of Advan AVS 18" wheels which i can include as an extra cost or replacement for the Rays Volk GTS wheels. (subject to price adjustment)
The pictures don't justify how this car shines and looks under the sun, anyone with a real interest in this type of car will be impressed.
http://www.carsales....0/?Cr=6&sdmvc=1
check out the link for pictures. thanks for viewing
https://www.sau.com.au/forums/topic/439004-2004-nissan-350z-track-edition/
No, I had an interest a while back but i've put a deposit down on a fuel efficient daily.. I don't get much time to enjoy the car anymore so down grading seems like the best option..
Thanks for your interest..
  • 3 weeks later...
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
