2004 Nissan 350Z Track Edition
Make: Nissan
Model: 350Z Track
Year: 2004
Body Style: (Coupe/Roadster/etc)
Colour: Pewter Grey
Version: (Track/Touring/Anniversary/etc)
Engine NA
Transmission: Manual
Interior Material/Colour: Sunburnt yellow
Odometer: 12*,***kms
Price: $24,500 negotiable
Contact Details: 0410888383
Comments:
Up for sale is my 2004 Nissan 350z Track Edition. The car has been great since the day I purchased it, I've never had any trouble with it, the car is serviced regularly by me, the oil gets dumped every 2500 to 3500 kilometres depending on how burnt the oil is. I have been told this is excessive but I don't like running with burnt oil.
Over the years of ownership I have upgraded some components for better performance as listed below:
CUSCO ZERO 3 - COIL-OVER SUSPENSION (20 way adjust-ability)
CUSCO - REAR CAMBER ARMS
CUSCO - FRONT A ARMS
CUSCO - FRONT AND REAR SWAY BARS
This set up alone cost $4000, I didn't want to lose comfort but be able to customise it easily to different drive types. Drives just like factory now with a bit more sharpness plus room to improve with its adjust-ability.
(complete OEM suspension + camber + a-arms + sway bars can be included)
TOMEI - EXPREME V2 HEADERS
STILLEN - HIGH FLOW CATS
X FORCE - EXHAUST SYSTEM
K&N - COLD AIR INTAKE, AND PLENUM SPACER
(complete OEM exhaust can be included by request)
These modifications have opened up the throttle response and given the car a exotic exhaust note without having any annoying back pressure sound while cruising. The only time there is any rasp in the exhaust note is in 2nd gear at WOT which in my opinion fits the car.
VOLK- GTS 19 INCH (9.5" front and 10.5" rears - brand new these cost $4600 plus shipping)
Currently running on about 80+% tread with federal tyres evo 595's, the grip on these tyres is awsome, (medium to soft tyre).
NISMO - TITANIUM SHIFT KNOB
I-POD CONNECTIVITY - integrated into the OEM stereo and also charges the ipod/i-phone
the standard stereo sounds great, good balance for the cabin setup.
(extra speakers included + oem head unit)
The clutch and flywheel have been replaced with a custom single plate heavy duty clutch, and a extreme single mass lightened flywheel late last year. There is some light chatter from the flywheel but isn't overly noticeable while driving but the clutch peddle is very light.
As a standard car it is solid on the road with very minimal road noise, with cruise control for freeway driving factory Brembo braking system, this car is the complete package with nothing to spend.
The Zed has been meticulously maintained and never missed a beat. Regretful sale but selling to cater for other commitments.
I highly doubt you will find a Z car like this one, there are some chips in the front bar and a small dent in the passenger door (whilst in carpark) but overall for a 10 year old car it is immaculate.
No low ballers please, anyone that has a real interest please call or text me with any questions, I'm am negotiable on the price to an extent and have a set of Advan AVS 18" wheels which i can include as an extra cost or replacement for the Rays Volk GTS wheels. (subject to price adjustment)
The pictures don't justify how this car shines and looks under the sun, anyone with a real interest in this type of car will be impressed.
http://www.carsales....0/?Cr=6&sdmvc=1
check out the link for pictures. thanks for viewing
  • 3 weeks later...
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
